Old 05-15-2011, 12:33 PM
lobsterman lobsterman is offline
Rep: 19 Posts: 47
Hi all,
Can epoxy resin be used over poly ???, I am building a 12' stitch and glue skiff, and i have done the bow and transom seams with a filler and covered them with f-glass tape with poly resin (the twisted copper stitches were left in, and encapsulated in this). I have yet to filp it and install the bottom sheets, (as i am working outside and the weather has not been too cooperative yet ).
But after reading all the benefits of epoxy rather that poly i am wondering if i could do the exterior of the hull with epoxy now that i have already done a few seams with poly ???.
P.S. years ago i had fiberglassed over a 20' lobsterboat with only poly resin + mat, and i had used a marglass short strand filler on all the seams before glassing it, and it seemed to hold up quite well for the next several years that i owned it.
9mm plywood cover with fiberglass Jakjit Singh Wooden Boat Building and Restoration 29 10-05-2009 07:00 PM
How much fiberglass over plywood? San Juan Sailor Boatbuilding 6 03-31-2009 12:00 AM
fiberglass on plywood Jan Van Boat Design 6 07-25-2006 03:30 PM
that is the diference between plywood and fiberglass? tamkvaitis Boatbuilding 9 12-27-2005 06:11 PM
Planks to plywood or fiberglass ajoan Wooden Boat Building and Restoration 2 10-25-2005 04:09 PM
