Old 04-14-2010, 03:55 PM
cri8bat cri8bat is offline
Plywood Boat Construction Plans - Step by Step Guides to Build a Boat Out of Plywood
By [http://ezinearticles.com/?expert=Smit_Chacha]Smit Chacha
Building a boat out of plywood may sound a bit daunting, but if you have boat building plans with you the entire process of plywood boat construction gets really easy!
These plans are very well constructed; they contain detailed illustrations that guide you step by step in the whole process of boat building.
These plans are a must have especially when you have limited DIY skills or experience. Although professional boat builder still use these them, simply because they help them to reduce the costs the project.
As I mentioned earlier these plans contain step by step illustrations that guide you from start to finish, the entire process of boat building. By simply following the detailed illustration you will be able to cut timber (plywood), design your boat and finish the construction of your vessel.
In these plans you will have loads of options or boat designs. Or should I say variations of the same boat design. From the most luxurious one to the most cost efficient one. These guides will assist you step by step in constructing the ideal boat design that suites your needs.
The boat construction process gets really easy when you have these boat construction plans with you, and once you finish your very first vessel you will realise that DIY boat building is so easy. And then you will get addicted! Seriously, you will just not stop from there. You will then realise that you can build better boats and the building cycle will simply not stop.
After a while you will realise that there is a lot of money to be made, how much does a brand new boat cost? Thousands of dollars! You can start your very own custom boat building business! And earn hundreds or maybe thousands of dollars!
Where to I find these awesome plywood boat building plans? Just grab them from this website: http://www.boatdesignplans.info and start building your boat from today!
Article Source: [http://EzineArticles.com/?Plywood-Bo...od&id=3960495] Plywood Boat Construction Plans - Step by Step Guides to Build a Boat Out of Plywood
Old 04-14-2010, 04:49 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
http://www.hostmybb.com/phpbb/viewto...54&mforum=easy Has lots here on plywood construction and DUFlex construction... For plans look here http://www.thecoastalpassage.com/cheapcat.html and that is in Australian dollars and he builds them at that price so no ******** either...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 04-14-2010, 09:57 PM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Sounds like someone trying to sell something. This should be in the marketing section.
Old 04-15-2010, 12:04 AM
masalai
Oh well, You may have the honour to ask Jeff to delete it as it is spam...
Plywood 15.5' Boat Construction Newbie needing help Uniquity Wooden Boat Building and Restoration 11 03-19-2010 11:07 AM
Step by step to design your boat! apex1 Software 115 11-20-2009 11:01 AM
Redesigning a step boat BlueMind Powerboats 9 01-11-2008 12:40 PM
Foam/Plywood boat plug construction ?s cla17 Boatbuilding 22 05-21-2005 03:44 AM
Foam / Plywood Boat Plug Construction ?s cla17 Materials 2 05-18-2003 07:45 PM
