Old 10-25-2005, 03:59 PM
ajoan ajoan is offline
Rep: 10 Posts: 3
Planks to plywood or fiberglass
Have a 52' chris craft its been out of the water for a while,most of the plank on the bottom is gone. I was thinking of replacing the bottom with plywood and then fiberglass or should I use fiberglass core then fiberglass.
Old 10-25-2005, 05:02 PM
chandler chandler is offline
Rep: 16 Posts: 378
Take a look at the bottom as a whole. If the planking is as bad as you make it sound, start with the frames and keel before you bother with the planking.
Old 10-25-2005, 05:09 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
This is not to make you feel bad or put you down in any way. But if you have a boat of that size and you are asking complete strangers. Would not the advice of several LOCAL builders come first? They can actually see how bad the rot is. Then ask us for opinions. Yes you can put a couple of layers of plywood staggered on top of one another and the hull would be stronger than steel. But at what total cost? $$ is usually not unlimited.
Fiberglass center console for 25 bertram ky87le Boat Design 1 02-19-2006 04:42 PM
how do you make your own fiberglass body huntermike32 Fiberglass and Composite Boat Building 12 11-02-2005 06:43 PM
Fiberglass, complete chopper & coater setup for sale stellar Marketplace 0 10-23-2005 10:04 PM
Boatbuilding plywood rdbct Wooden Boat Building and Restoration 3 02-05-2005 06:12 PM
mahogany marine plywood structure? blackspot Materials 13 10-06-2004 09:39 AM
