| Planking width? I am getting ready to plank the transom on the boat. It is 15"X36" and has a rake. For pure ethicists what is the ideal width of the planking and should I put a slight bevel on the seam edges to accent the planks? I have had it covered in random width planks and it looks good that way. It will be left natural and varnished. What are the rules?? |
| No excact rules btw 1'' to 1'.. better the planks, wider.. "betternes" depending of the quality of the timber and likes/dislikes of the builder So no help.. Nice work you doing (following your building thread). Teddy |
| Thanks for the reply. I used scrap from the framing and came up with this, which I like! It is still full 1", I will plane it later. As you can see, my material is near perfection! The pieces with minor blems I have used as battens and the center of the laminations! Thanks again for your reply. |
| Belatedly, I would suggest quarter-sawn wood no matter what species you use, and in general go narrower if there's no curve across the transom. A narrower board, like 6" wide, ensures the cauking won't be asked to stretch or compress too much, but some woods like cedar can be wider without problems (maybe 10"). I've seen oak used in wide pieces on flat transoms, which is asking for trouble if poorly maintained. There's a reason transoms are sometimes curved, and it isn't all for looks. Alan |
| Thanks Alan; The planks are 4,2,3 and 5", they are cedar, that is what I have to work with. The bottom board is backed up to a 5" wide frame member and that should be about as far in the water as the transom will get, I am just using paint or varnish between the boards, they fit very nicely along the seam. I bought a large stack of it, 1"X12"X12' rough cut, full inch thick that was cut wrong, it was just 11 1/8" wide. I paid $7 a piece and it is nearly all clear or just a few small knots most of which don't show on the other side. I can build several more small boats, or a lot of clocks! Thanks Brad |
| Chine width | Boysie | Boat Design | 3 | 02-18-2008 03:48 AM |
| Tapered chine width | Nojjan | Boat Design | 18 | 08-06-2007 05:24 AM |
| boat width | grp.boat | Fiberglass and Composite Boat Building | 1 | 06-14-2006 07:30 AM |
| Cruising Cat Width | Inquisitor | Boat Design | 69 | 11-13-2005 01:31 PM |
| Strip planking vs wide planking | jfblouin | Wooden Boat Building and Restoration | 26 | 08-11-2005 10:00 PM |
