Old 01-16-2004, 01:59 PM
DrewBird DrewBird is offline
Plan to fit sail kit - Any reccomendations?
Hi All,
I have been interested in building a small sailboat for a couple of years. Ideally I would like to make a car-toppable boat capable of being sailed by one, but that could carry two at a pinch. Construction needs to be simple, as this is my first time
The thing is, that last year a friend of a friend was selling an old (1970's) 10 ft Metzeler inflatable with a sail kit. I had never seen anything like it, so bought it for $350 CAD thinking that the sail kit would be useful for my future boat building plans. What made it worth it, for me, is that the mast is sectional. Each of the four pieces slots into each other, and then into a base plate on one of the wooden floor sections of the boat. A sectional mast makes my dream of a car toppable sailboat even more real as I can fit and secure the mast (in its sections), inside the boat. The inflatable itself is in pretty poor repair, so I will probably try and patch it up enough to use it as a rowing dealy, but I now have the time to look properly at the building of a sailboat.
My question is this, and don't forget it is a very naive question from a newbie. What information do I need to compile about the sailkit in order to match it to a boat plan, or is such a match very unlikely to be successful? Also, any reccomendations such as a type of boat or boat plan would be welcome. I currently own an Enterprise which I have a great deal of fun with. However, the thrill of sailing a boat that I had built, even if it didn't perform as well as the Enterprise, would be quite the kick.
Any and all help or advice welcome and appreciated.
DrewB.
Old 01-17-2004, 10:55 AM
Rep: 1493 Posts: 7,447
The surface area is the most important. If the shape is not exactly what the plans call for it shouldn't make a big difference. In small boats, the crew weight affects trim enough to compensate for small differences.
Old 01-17-2004, 01:36 PM
Unregistered
OK, thanks. Now would I need to measure the mainsail and the gib? I had better get my highschool geometry books out.
Your reply is much appreciated.
Drew.
Old 06-05-2004, 06:42 AM
Artur Villemsoo
Metzeler boat
I have the same boat, but withoutn any instructions, also there can be some missing parts. Is ther possible to get any manual or ...
artur_vil@hotmail.com
Old 06-05-2004, 06:12 PM
briany briany is offline
Rep: 10 Posts: 13
Hi, I found myself with a spare Enterprise rig and built a 12 1/2 foot ply dinghy to take the mast and both sails (cruising and racing) If you only have the larger sail it is worth having reefing points fitted.
I used a Selway Fisher design called a Hobo. This weighs about 125 pounds and is quite easy to build. you might be able to adapt the inflatable rig but I would recomend the Ent rig. I have won several races with this and it will just take two.
Selway Fisher are at 15 King Sreet Melksham Wiltshire England SN12 6HB
Tel / fax 01225 705074
Hope this helps, Briani
sail aerodynamics Hydrodynamics and Aerodynamics 473 04-04-2012 05:04 AM
Why does a cutter rig point higher & sail faster? Rich Kinard Sailboats 140 08-20-2008 06:43 PM
Loose footed mains Polarity Sailboats 65 09-14-2007 04:37 PM
Sail & Rigging plan for 44' ketch Willallison Sailboats 4 01-15-2003 02:00 PM
Classic boats: how to design the sail plan? Gades Sailboats 6 08-01-2002 07:30 AM
