  #31
Old 06-11-2007, 11:49 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
Oh, I see. I hadn't thought of thick veneer. Should simulate batten seam then. Should be quite strong and light. Does the fir go on with screws first, or do you add the second layer on the bench? The first would eliminate bungs but be very challenging to glue well. The second would glue easily but would show bungs and require the full thickness be perfectly spiled.
A.
  #32
Old 06-11-2007, 01:01 PM
ucb4ume ucb4ume is offline
Rep: 73 Posts: 49
Alan,
The first layer, marine plywood, will be gleued and screwed to the topside frame. After that layer has cured and has been faired, I'll apply the mahogany veneer with thickened epoxy and tempory staples, which will be removed later. The staples do leave small holes in the veneere, but I'll fill them with a combination of epoxy and mahogany sanding dust. After fairing, it'll be difficult to find the staple holes.
This is the same method I used on my previous boat and it does create a very strong, stiff and suprisingly light hull.
  #33
Old 07-10-2007, 09:12 PM
Rep: 73 Posts: 49
More pictures
I've installed the top side planking and have began the fairing process.
Here's my favorite long board and air file. Both are essential for fairing.
  #34
Old 07-10-2007, 09:24 PM
alan white's Avatar
The trick is to keep the beer from spilling...
  #35
Old 07-11-2007, 06:17 AM
VKRUE's Avatar
VKRUE VKRUE is offline
Just another boat lover
Rep: 64 Posts: 254
Looking great !
Keep up the good work.
Best wishes.
Vic
http://vics-little-workshop.blogspot.com/
  #36
Old 07-22-2007, 10:41 PM
VKRUE's Avatar
Rep: 64 Posts: 254
Quote by Ucb4ume: After that layer has cured and has been faired, I'll apply the mahogany veneer...
Hey Uc, what did you use to fair the surface before applying your veneer ?
I'm thinking of applying veneer to the topsides (around the cabin) of my boat (when I get that far) to incorporate that "natural wood" look into a boat that will be mostly painted.
Best wishes.
Vic
  #37
Old 07-23-2007, 01:21 PM
Rep: 73 Posts: 49
VKRU,
I am using WEST 410 Microlight Filler with WEST epoxy. It's light and easy to sand.
http://www.jamestowndistributors.com...rolight+Filler
  #38
Old 07-24-2007, 06:23 AM
VKRUE's Avatar
Rep: 64 Posts: 254
Ok Uc...
Thanks
Best wishes.
Vic
  #39
Old 08-03-2007, 09:20 PM
Rep: 73 Posts: 49
A change of plans
Well, after several months of thinking, I decided to go ahead and laminate the bottom with a 1/8 inch mahogany veneer. Originally, my plan was to just glass the plywood bottom and paint it, but I like the way the mahogany looks and it will add strength. On the down side, it takes longer, cost more and will add about 50lbs to the over all weight. The combination of plywood and mahogany will create a half inch thick bottom. In addition, I plan on using 7.5 oz. S-Glass/epoxy over the mahogany.
As a side note, I re-saw my own veneer planks using a cheap table saw and a thickness planner. It's not much fun, but I am able to get three 5" wide by 1/8" thick planks from 3/4 stock. The blade on my table saw only sticks up 2.5" inches above the surface of the saw, so I have to run the 5" wide stock through twice. After a couple of passes through the thickness planner, the planks are ready for lamination.
Here's a couple of pictures of the re-saw process.
  #40
Old 08-03-2007, 11:54 PM
VKRUE's Avatar
Rep: 64 Posts: 254
Looking pretty good Uc
Best wishes.
Vic
  #41
Old 10-12-2007, 05:45 PM
Rep: 73 Posts: 49
It's been
...and it's finally beginning to cool off a little. It was 55 this morning with a high of about 80 with a light north wind.
I've finally gotten all the veneers glued down, but I still have a lot of sanding left to do. The bottom has one coat of epoxy just for protection, but I'll probably sand most of that off before laying down the S-glass. After the glass comes the lift strakes, spray rail and final finish coat. Then she'll be ready to turn over.
  #42
Old 10-12-2007, 05:48 PM
Rep: 73 Posts: 49
It's been a long hot summer here is South Louisiana...
...and it's finally beginning to cool off a little. It was 55 this morning with a high of about 80 and a light north wind.
OOPS! How'd that picture get in there? That's my youngest son in Tiger Stadium. Geaux Tigers.
  #43
Old 12-09-2007, 03:27 PM
Rep: 73 Posts: 49
Well, it has been a little over a year since I started this project and I'm not as far along as I thought I would be. I thought I would be finished by now, but I'm still working on the bottom.
I've glassed the bottom and installed the lift strakes and chine strakes. Next I'll install the spray rail and give everything one more coat of epoxy. Then she'll be ready to turn over.
In addition to the wood work, I also purchased an outboard motor this week. It's a used 125HP Mercury, year 2000. With a 19" pitch prop, I calculate it will push this boat about 45 mph.
  #44
Old 12-10-2007, 08:23 AM
VKRUE's Avatar
Rep: 64 Posts: 254
Looking really nice :)
She's looking real good. I've been thinking about you and your boat lately. I've been layed off for the winter now and am starting to work on my boat. I have a long way to go.
I was wondering about the glass layers.
Don't have time right now but I'll be in touch.
Best wishes.
Vic
  #45
Old 12-11-2007, 08:40 PM
Rep: 73 Posts: 49
Hey VKRUE,
I installed one layer of S-Glass on the bottom with the lift strakes glued and screwed on top of the glass. I'll also cover the lift strakes with S-Glass, but that's the only glass I will put on this boat. The top sides and deck will be epoxied and varnished, but no glass. I don't really like the slightly cloudy finish you get with glass and epoxy. Maybe I just don't know how to wet it out properly.
Sounds like you will have lots of time to work on your boat this winter. Is it normal to be off work for the season?
We're at full employment down here in S. Louisiana. With oil at $90 per barrel, everyone is working overtime to pump as much as possible.
Videos-pictures Mihajlo Wooden Boat Building and Restoration 2 01-26-2007 06:47 PM
Borg Warner Velvet Drive Model 72c Current Model DAVID HOSEGOOD Diesel Engines 1 12-27-2006 12:30 AM
Wind/Wave and Current Effects on Cargo Ships MattD Boat Design 5 08-30-2006 03:10 PM
Route Plotting wrt wind and current rdickins Open Discussion: All Things Boats & Boating 3 07-29-2006 10:42 AM
New Design from Current Specs cdreams Option One 6 02-28-2006 11:00 PM
