| Peel Ply on plywood/Epoxy Hy to all; A question about the use of Peelply on sheeted Plywood. I have some experience with foam core sandwich building, where we always use peelply for a smooth finish and to remove resin excess. Now I want to start building a sailboat with plywood (multichine) with exterior covered with glass/epoxy. I'm thinking about using Peelply for the finish, but I didn't find informations about that (in the Gougeon's Brother book is not mentioned). Has someone experienced this solution and can give some advice about? many thanks and good wind! |
| Google "Peel Ply" |
| Peel ply will leave the surface slightly textured, which is intentional. If you need additional coats, this is the way to go. If you're looking for a smooth finish then use a smooth material like Visqueen (the clear plastic they sell as painter's drop cloth in hardware stores). The DuckWorks article, Pericles listed above details this. |
| Many thanks! Your link will be very helpful! |
| Triman, The polyester film is stiffer than Visqueen, so it is almost self leveling. Here is a source in Europe. http://www.alcanthermoplastics.co.uk...ermopet-g.html PETG peels off the cured epoxy very easily. Pericles |
| Peel ply.... | Roly | Materials | 49 | 12-01-2011 01:41 AM |
| Epoxy and marine plywood | micag | Fiberglass and Composite Boat Building | 0 | 07-17-2006 12:17 PM |
| Peel-Ply Removal | bluwtrlynn | Fiberglass and Composite Boat Building | 5 | 02-21-2005 12:47 PM |
| absolute beginner ply/epoxy or ply/glass | wannabe | Materials | 9 | 08-13-2004 06:01 AM |
| secondary bonds with peel-ply | Ian | Materials | 2 | 07-03-2004 07:43 AM |
