Old 01-03-2008, 11:26 PM
Eagle Boats Eagle Boats is offline
Rep: 16 Posts: 169
Overarm router
I am going to start building wood rudders and teak hatchboards. I need tools that will build them with the least amount of fuss but maintain a high degree of finish and consistency on a production basis. I have an industrial size shaper, but I am wondering if an overarm pin router would be better. Any insight would be much appreciated.
Old 02-24-2008, 09:18 PM
john92021 john92021 is offline
pin router
If you are going to be doing production what you really want is a CNC router. They have come down in price over the past few years and pay for themselves. I employee on a CNC can do the work of 3 working by hand, and you can lease one for the price of 1 employee so you are still ahead.
Old 02-24-2008, 10:28 PM
Rep: 16 Posts: 169
John, thanks for your response. I build fiberglass boats with a minimum of wood trim. I could not justify the expense based on the amount of work that would be necessary. In addition, space is at a premium at my shop. The pin router has a smaller footprint.
Due to many shops switching over to CNC, there seems to be a lot of pin routers on the market. I have a chance to buy a SCMI R9 in very good condition for $900. The price seems too good to pass up.
I will still investigate CNC machines, as I am a firm believer in using tools that will reduce the amount of manhours it takes to perform an operation. When time, and especially money permits, I may go for it. I would like to hear about your experiences with CNC.
Old 02-25-2008, 12:41 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
The hatchboards are easily done with a rabbeting bit on a common router, hand held, and then stacked, clamped, and cross-cut both sides with a fine-tooth carbide saw blade on a skilsaw run against a clamped-on angled template.
A rudder requires bevelling, and a jig can be made that uses an air or electric (offset grinder/polisher, etc.) and a vee that the rudders are drawn through. A 36 grit disc makes short work of the bevel, which can be finished with a hand held 6" RO sander.
The leading edge can be shaped with a round-over router bit, hand held.
Unless thousands are being made, stay low-tech and stay away from expensive equipment. It isn't cost-effective at typical sailboat production runs unless you will be competing with the very biggest competitors.
Alan
CNC router time available! ericCB Marketplace 0 08-20-2007 11:58 AM
CNC Router Services - Mesa,AZ innovative Services & Employment 2 10-03-2006 12:54 PM
Fairing planks with a router LP Wooden Boat Building and Restoration 8 03-19-2006 07:37 AM
5 Axis router movie Splint Fiberglass and Composite Boat Building 1 07-27-2005 11:30 AM
CNC router services duluthboats Services & Employment 1 04-15-2005 09:56 AM
