Old 01-29-2007, 12:30 AM
Kraftwerk Kraftwerk is offline
walking the plank
Rep: 10 Posts: 8
Opinion on this wood
Hello,
Rather new to this...
I am looking at a particular sailboat made of pitch pine over oak frames.
What is your opinion of this particular wood?
The vessel is about 50 yrs old. Restoration is 80% complete. Needs hardware,
rigging and cuddy cabin.
What are the weight differences in general between a wood boat and f/g
of the same size/type.
What are the advantages of wood (compared with f/g) other than it is compleatly georgous/ breathtaking?
Thank you,
jt
Old 01-29-2007, 02:24 AM
PAR PAR is online now
Rep: 2891 Posts: 8,798
Pitch pine over oak, 50 years old, 80% complete isn't nearly enough information to provide you with anything specific.
Pitch pine is on the heavy side, though quite durable. The framing material, I'll assume is white oak and is typically seen. Needs a cuddy (furnishings too?) which can be intricate work, needs hardware, rigging (sails too?) which can be a large percentage of the cost in the total build.
Comparisons are imposable without dimensions, but generally wooden boats can be lighter in smaller sizes (not always), in larger sizes (over 30') it has difficulty keeping it's weight competitive with well built 'glass yachts. Both materials, like all building materials have good points and bad. Both materials can be built very light or very heavy and everything in-between. Much depends on the designer and the design's intent.
Old 01-29-2007, 05:21 PM
walking the plank
Rep: 10 Posts: 8
Thanks Par. It has a mast and sails. It is a 30' racing Dragon so there are no furnishings to speak of. I will see it soon in person, hopefully.
Old 01-29-2007, 08:41 PM
DanishBagger's Avatar
DanishBagger DanishBagger is offline
Never Again
Rep: 523 Posts: 1,543
»It is a 30' racing Dragon«
Nice one, mate!
Old 01-29-2007, 10:26 PM
walking the plank
Rep: 10 Posts: 8
Yes it is nice.
Such great lines. It is almost as if you can hear the pencil against paper and smell the pink eraser. When I look at todays boats (or cars) I just hear the mouse-click, their chilly profiles leave me cold.
There are so many 'sane' options out there: F/G boats with all their rigging and sails in tip top shape, less money. I am crazy or what? This one needs work. I haven't met it in person yet though.
I might just go with the modern version: Hello Plastic! ('Modern' here meaning the 1970's or even a trusty J-27 from the 80's) I hafta think about this one, seems like a big step.
Old 01-29-2007, 10:28 PM
Never Again
I think you're perfectly sane.
Old 01-29-2007, 10:59 PM
Never Again
Btw, I don't know if you know this site:
http://www.borresen.com/new/news_dk.html (click "dragon", obviously).
Prince Henrik's boat:
(Børresens Boat Yard).
Also, there are denship's GRP ones.
Last edited by DanishBagger : 01-29-2007 at 11:07 PM. Reason: Added another picture
Old 01-30-2007, 05:27 PM
walking the plank
Rep: 10 Posts: 8
Prince = Unlimited funds
Well wouldn't you have the same boat?
Old 01-31-2007, 05:19 AM
Never Again
True, but as inspiration as to how great a mahogony dragon can look in race outfit I think it is great. He does race that thing.
Old 01-31-2007, 11:46 AM
walking the plank
Rep: 10 Posts: 8
Super looking boat. The hull is f/g or glass coated wood ?
Old 01-31-2007, 12:13 PM
Never Again
This is from the CM Grand Prix and the CM Racing:
»Method of building
The hull is built "cold moulded", veneers placed on a master plug, under vacuum pressure at high temperatures and glued together with epoxy glue (specially developed for Borresen). This method of building gives you the stiffest hull possible within the international Dragon rules. At the same time we have been able to optimise the weight distribution in the boat. The hull is long boarded and faired for the highest finish possible and painted with a 2 component high gloss paint.
The deck is also made in wood with mahogany cabin top, covering board and cockpit coaming, plywood deck, inside-outside all paint in one colour. This gives a very light and stiff deck. Boats with wooden deck have always appeared to be fast because of a better stiffening compared to boats with fibre glass decks. The cockpit floor has been raised in two levels for better working positions. The cabin top has been designed in a new more aerodynamic shape.«
I believe that the deluxe is through-and-through mahogany.
However, none of the three are GRP.
As far as I know, it's Denship that makes the GRP-ones.
your opinion - use of PVs on your boat PVboat Boat Design 0 10-22-2006 10:49 AM
Need your Opinion: Yacht Designing business in SE Asia chomchan Open Discussion: All Things Boats & Boating 2 10-20-2005 01:06 AM
1956 ChrisCraft Project, your opinion please... PeterH Wooden Boat Building and Restoration 13 03-20-2005 06:53 AM
Cruiser opinion Ikhanton Powerboats 0 04-14-2004 02:47 PM
opinion Stephen Gray Boat Design 0 02-24-2004 02:40 PM
