Old 08-17-2007, 10:40 PM
old man old man is offline
Rep: 10 Posts: 21
Is it OK to have monel fastners below the waterline?
I know silicon bronze is the metal of choice but is it Ok to have monel as fastners for planks on the hull? I have a 27 year old chesapeake bay workboat. My skeg bolts are 1/2" galvanized, shaft stainless, strut and thruhull fittings bronze, and all the wood fastners on the boat are monel. I know they keep stressing keep all underwater metal the same having a stainless shaft and bronze rudder almost seems the norm these days.
Old 08-17-2007, 11:31 PM
USCGRET/E8 USCGRET/E8 is offline
Senior Chief
Rep: 41 Posts: 164
check this out:
http://www.coastalfasteners.co.nz/galvanic_action.htm
Old 08-18-2007, 02:33 AM
hansp77 hansp77 is offline
Rep: 200 Posts: 691
Hello old man,
I have a 45 yr old (marine ply) boat originally fastened with monel- and with some bronze fastening as repairs, with a stainless prop shaft and bronze prop and rudder post. I had to replace my deck last year so got to check out some of the above water fastening. The bronze was totally stuffed, looked ok from the outside but was brittle and discoloured insided. The monel didn't look too good, was green etc, but was totally fine. I have kept most of the screws nails I pulled as they just looked too good to throw out.
I don't know what it is happening under the water, but from what I have been able to learn Monel is pretty damn good.
My boat has been in the water its whole life, and during that time has never (apparantly) needed sacrificial anodes (the old owner said the only time there was an issue was when a steel boat was in the pen next to him).
But I really don't know,
Someone like PAR may just come along soon and share their knowledge.
Old 08-20-2007, 12:29 AM
Rep: 2891 Posts: 8,798
Monel is easily the best fastener material for the marine environment. Most of the bronzes are a good second.
Old 08-29-2007, 06:26 PM
chandler chandler is offline
Rep: 16 Posts: 378
Monel is the best and most expensive. In combination with other metals in salt water you need to check a table of galvanic reactions.
Old 08-29-2007, 07:04 PM
charmc charmc is offline
Rep: 833 Posts: 2,390
Monel 400 is a nickel/copper alloy (61.5%/31.5%), while bronze is mostly copper, with a small amount of tin or silicon. The high nickel content in monel makes it one of the best materials in resistance to seawater corrosion. Bronze also has good resistance in seawater.
The nickel content makes monel more costly, which might be why bronze fasteners are more common.
The one limitation for monel fasteners is on steel hulls. That particular combination can induce hydrogen charging, which makes the monel brittle. On wood planking, monel is one of the best.
Best,
Charlie
Strip Building Fastners hulsey51 Wooden Boat Building and Restoration 7 08-04-2006 09:00 PM
Confusion Below the Waterline Texas Boater Wooden Boat Building and Restoration 2 05-20-2006 04:40 PM
formula for finding waterline? Baldur Boat Design 13 06-17-2005 05:21 PM
Hatch Fastners that twist & release from topside Will_3 Wooden Boat Building and Restoration 1 09-13-2004 02:23 PM
designed waterline? huw Boat Design 3 06-05-2004 01:29 AM
