Old 04-01-2008, 09:35 AM
bntii's Avatar
bntii bntii is offline
Rep: 1073 Posts: 704
Ok- another brass/bronze question.
I have purchased and installed a 'keel plug' fitting in my 40' sailboat.
This fitting is a 3" flange with a tapped center that takes a 1 1/4" plug.
It is installed so as to provide a means of keeping the hull draining during haul outs.
The folks who made this fitting in their wisdom made the flange out of bronze and the plug out of brass. The above is boldly stated in the description of the part in the catalog.
What the heck?
Is the ideal that the plug is sacrificial? Is this some attempt to protect the flange?
The whole thing seems so fishy that I am looking about for a proper bronze plug to replace the supplied brass one with. Its tough to find as the plug has been milled with a 1/2" square hole to take a driver to extract the plug for hull draining.
Any ideals? Is this fitting good to go as provided?
Ok- another brass/bronze question.-garboard_drain.jpg
Old 04-02-2008, 08:34 PM
Rep: 3125 Posts: 9,403
What you want is West Marine part no. 350108 or you can check with Perko or Groco for a similar bronze plug.
You're correct the brass plug will become "sacrificial" in sea water.
Old 04-03-2008, 07:45 AM
bntii's Avatar
Thanks PAR,
Will get one from WM
Brass vs. Bronze screws crosscut Wooden Boat Building and Restoration 33 08-01-2008 12:16 PM
Silicon Bronze vs Brass flydog Wooden Boat Building and Restoration 10 07-29-2007 09:40 PM
Nickel plated Brass screws rona Boat Design 1 07-25-2005 05:47 PM
Nickle plated brass rona Boat Design 0 07-22-2005 08:28 AM
Brass CZ112? fasteners? rona Boat Design 6 06-10-2005 07:06 AM
