| No-offset table, how to loft? hello! I have original drawings of the type in the picture attached. Along with the drawings I have the dimensions of the boat as specified in the design. But I don't have the offset tables. How do I go about lofting the design with the offset-tables missing!?! Can you point me to some good reference for this? Thanks Mohan |
| Draw a set of lines over the plans you have and create your own table of offsets. Enlarging/Copying the plans to a standard size will help a great deal. 3/4 inch to the foot or 1 inch to the foot is simple to use with a scale rule. FF |
| Or you can model the hull in Rhino (or TouchCad since you are in Stockholm :-), then section it and have the molds laser cut. This example is made in 5 minutes. I used your picture as a background and draw very quicly three stations, midship, transom and close to the stem, and then lofted the surface. You can smooth the surface and check the volume before you build it. Maybe lofting on the floor is more fun. |
| What is Michlet hull offset data form?! | Dante | Software | 3 | 08-20-2006 01:22 PM |
| Single Sterndrive Offset | fede | Boat Design | 3 | 05-22-2006 10:59 AM |
| Offset single prop - which direction? | Ben Lindenberg | Propulsion | 7 | 11-10-2004 12:53 PM |
| Problems with creating an offset file with autoship | koen | Software | 2 | 08-06-2004 03:37 PM |
| hull offset data... | wawa | Education | 0 | 08-03-2004 03:08 AM |
