Old 07-24-2007, 04:17 PM
TatTude TatTude is offline
Rep: 10 Posts: 7
newbie help plz....building a off the wall boat(s)
Hello, I am getting into this boat building thing just like the rest of you. However mine is on 2 different levels of boats.....The first level is it will be R/C (Radio Controlled) and the second one is that it will be a min. of 13' long and 4-6 feet wide and will be of the offshore racing class mainly the Cigarette style.
Now with that crazy statement made how do I get started? I know how to work with wood to some point mainly balsa and lite plywoods.....as well as fiberglass and most kinds of epoxys....my main questions are how do design and start building the hull? It must be a Deep V class just like this Cigarette boat in this pic.
As for powering this monster I would like get started on the hull before desiding on what engines will go in it. I am thinking about either one big lawnmower engine that would be turbocharged or 2 smaller R/C 150cc aircraft engines.
Thanks for looking
John
Old 07-24-2007, 08:11 PM
Rep: 505 Posts: 1,658
there are experts in this field ,,on this site ,,luky day for you,,,,,doug lord,is one,,,,,good luck ,sounds like fun,longliner
Old 07-24-2007, 08:24 PM
Rep: 10 Posts: 7
Thanks for the info! Hopefully he will chime in!?!?!?! If I can get what I want all worked out then I want to start selling these.....Also I would make bigger ones a person can ride in.
Old 07-24-2007, 08:36 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
PM Doug if he does not "chime in".
Welcome.
Tim
Old 07-26-2007, 04:34 AM
Rep: 10 Posts: 7
His PMs seem to be turned off so I sent him an email....I really need to get started on these projects...I have 7 customers wanting to make pre orders...anyone that can help would be HUGE!!!!!!
Old 07-27-2007, 06:55 PM
doug is trying to contact you ,,you have no pm adress,,,look up doug lord ,,longliner
Old 07-27-2007, 08:24 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
You might get 25 hp into 13 ft. A suggestion would be a 250cc motorcycle engine, single or twin. This would give you a clutch and ratios to choose from. A water-cooled 250 would be icing on the cake.
Alan
Old 07-27-2007, 09:30 PM
Rep: 10 Posts: 7
Please give doug my email ssosaleen@Yahoo.com....for some reason i cant see his PMs?
Old 07-28-2007, 08:23 PM
he tried ,,and was told ,,email malfunction,,,,why dont you have pm capabilitys?
Old 07-28-2007, 09:17 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
have you got a scaled design yet? or building as you go
Old 07-28-2007, 11:14 PM
Doug Lord
Rc
Geez! I looked in every forum but this one;thanks to Longliner for trying to help. Based on what I've read(13' scaled down offshore type powerboat-radio controlled) I would strongly urge you to not pursue such a large rc boat unless you're going to sell it to law enforcement. You would need a spectacularly costly radio system to begin to make it safe. The R & D costs to properly work this kind of system out would be very high in both dollars and time. If you insist on pursuing this idea I hope you would involve an independent marine test lab like Imanna to help you get it right.
What is your idea of how these things would be used? And to whom would they be marketed?
You can contact me at: lorsail@webtv.net or here now that I've found it. whew!
Old 07-29-2007, 01:16 AM
Rep: 10 Posts: 7
Hello Doug! great to hear from you!!! Though I dont know why you cant send me an email? Anywho, a little history about me....I have been in the R/C business and hobby for more then 20 years....give or take a year or two. lol There is really alot of high tech parts and engines in the hobby that could power something like this but maybe a little smaller? Though I do agree that a motorcycle engine would probably be best for power and what not for this size of boat....anyway I also fly model airplanes that are up to 50% of the full scale size that use 150 to 363cc gas engines....So i really think that the technology is there to support something of this size. I am just a total n00bie to designing a boat! But I also know when to say when and if something of this size is not something that can be done then I would still like to do this style just alittle smaller is fine too.....You had also asked where I would run something like this? well there is a couple big lakes around me that I can run a boat of this size and not have any problems...they have some small R/C hydro races there every year...
thanks John
Old 07-29-2007, 02:01 AM
Previous Member
Rep: 0 Posts: 0
We have a version here in Australia of what you describe that you can sit on - it is called a JetsSki. I expect you have them in the US as well. Just joking.
However a jet ski might be a good place to start. The hulls are proven and the drives are made to work in water. I would certainly consider an enclosed prop for something of this scale that could get out of control. Marinising a motorbike engine driving a prop brings in a lot of issues.
So a suggestion is to start with a jetski hull to produce a mould. You could lengthen is if you did not like the proportions. Then build a nice low deck.
If you want to start drawing up you own hull then download the free version of Delftship and learn how to use it. You should be able to model a power boat accurately by looking at various pictures. You could post your design here for critique but they are not difficult to shape. Detail of the design will depend on how you set up the engine. Forces a larger than in aeroplanes so you need stronger mounting points - a good reason to study a jetski first.
The things with the boat is a "V" hull possibly with a triangular flat planing section and planing strakes. Keep the weight low in the hull. Make sure it has ample solid buoyancy to stay afloat if it crashes and gets holed.
Rick W.
Old 07-29-2007, 02:28 AM
Rep: 10 Posts: 7
Rick W.
Hello Rick, How you have come with some good points! However I must say I like the jetski engine idea!!! However I do have some questions on how one of those engines works? where and how does it get the water to the engine if there is no holes in front of the engine in the hull ? I tryed looking for some vids on youtube and other info pics but really havent found much yet??? Im looking forward to hearing your thoughts and others on this idea.
Thanks John
Old 07-29-2007, 02:59 AM
Rep: 10 Posts: 7
Now I did find this and this is just badass!
http://www.youtube.com/watch?v=p9ryf-Uam0g
Newbie building 1st boat (runabout) footer32 Wooden Boat Building and Restoration 9 06-13-2007 07:58 PM
Pontoon boats, do they have to have a wall around the boat? Moose 200x Boat Design 1 05-23-2007 06:14 PM
Newbie is building a river cruiser..... newinertia Boat Design 37 03-26-2007 03:56 PM
Newbie to boat design and building wants to make own boat bigisland Boat Design 2 01-20-2007 01:03 AM
Building a 350: newbie finer points? curtis73 Gas Engines 41 11-04-2006 12:25 AM
