Old 03-01-2012, 04:10 AM
RobMarks RobMarks is offline
Rep: 10 Posts: 3
Newbie Boat Builder
Can anyone help me with videos and books on boat building please
Cheers Rob
Old 03-01-2012, 04:22 AM
sean-nós's Avatar
sean-nós sean-nós is offline
Rep: 325 Posts: 142
Hi rob what type of boat are you thinking of building. You can see some links to my builds below they are Glen-L boats and there books "boat building with plywood" and "inboard motor installations" are very good.
Old 03-01-2012, 03:36 PM
Rep: 10 Posts: 3
Wooden with ply mate, just a simple boat with an outboard
Old 03-09-2012, 02:41 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1404 Posts: 3,041
I can recommend looking at
http://www.devlinboat.com/stitchandglue.php
and I found his book and video to be a good starting point
Old 03-09-2012, 10:08 PM
Ike's Avatar
Ike Ike is offline
Rep: 1468 Posts: 1,520
look at Bateau.com or Glen-L at http://www.glen-l.com/
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 03-16-2012, 09:52 AM
Rep: 10 Posts: 3
Cheers Guys, I have found some plans and redesigned them to fit my needs.
One Question tho how can i draw/mark out the curvature to the boat ? is there some kind of nack to it
Old 03-16-2012, 10:19 AM
hoytedow hoytedow is offline
Rep: 2142 Posts: 4,227
Welcome to the forum, Rob.
Lofting
Hoyt
The TITANIC sank because it had a hole in it(still does). Submarine Tom
You just can't put too much info on your patterns. DGreenwood
Old 03-16-2012, 07:28 PM
rwatson's Avatar
This is always an exciting time - either marking the ply, or building the framework.
It depends on the building method.
Worst case, you have to calculate out a dozen points, and then try and get a smooth line to join them all up. For this, a length of straight, smooth timber that is thin enough to bend around the 'dots', will give you a great curve.
Best case, you take a disk down to your local cnc guy, and get them to cut out the wood.
What do you plans require ?
The overriding principle is that there will always be a bit of a discrepancy between the plans and what you cut yourself. The trick is just to make sure the discrepancy is the same for both sides of the boat.
Old 03-16-2012, 08:17 PM
Ike's Avatar
Ike Ike is offline
Instead of using a long thin piece of wood for a batten (or spline) to draw smooth curves, I use a 10 foot piece of 1/2 inch PVC tubing. It's cheap, bends around most anything and has a smooth edge (side, top, bottom?). It works very well and you can get them in the plumbing section at Home Depot or any other hardware or home improvement store, and they come in varying lengths. However, any batten will take on a set if you don't store it somewhere where it can lay straight. So be careful where you store it.
Ike
Old 03-16-2012, 08:29 PM
rwatson's Avatar
Originally Posted by Ike View Post
Instead of using a long thin piece of wood for a batten (or spline) to draw smooth curves, I use a 10 foot piece of 1/2 inch PVC tubing. .....
The problem I found with that is that being round, when you draw a line, the pencil wanders over the curved edge. You really need a flat edge to hold a pencil vertical.
Fibreglass Sail battens are good if you can drive nails into the flat wood and lean the batten against them.
Old 03-16-2012, 08:50 PM
Ike's Avatar
Ike Ike is offline
The pencil wanders over the curved edge
Initially I had the same problem but I just got used to making sure the pencil was straight up and down all the time.
Ike
Old 03-16-2012, 10:14 PM
Dirteater's Avatar
Dirteater Dirteater is offline
Rep: 217 Posts: 188
Hi Rob,
I used Door trim and a carpenters pencil,
and a black felt sharpy before lofting.
Old 03-17-2012, 03:45 AM
Yacht Designer/Builder
Rep: 3465 Posts: 11,665
I too have switched to man made batten stock, though I still have some nice long fir and mahogany pieces I use from time to time. I use flat extruded stock, rather then pipe, which eliminates pen wander as you scribe a line. This can be commonly had in 20' lengths.
PAR Plans
PAR Blog - fresh updates
Old 03-18-2012, 01:05 AM
ancient kayaker ancient kayaker is online now
aka Terry Haines
Rep: 2130 Posts: 3,318
Cheers Guys, I have found some plans and redesigned them to fit my needs . . .
How much of a redesign? As a self-confessed newbie is this a good idea? I admit that I also change designs to suit myself but I didn’t start doing that until I had a few boats under my belt first.
. . . One Question tho how can i draw/mark out the curvature to the boat ? is there some kind of nack to it
I’m wondering what kind of plans you have. There are plans that need a professional or experienced amateur builder to understand, and plans for newbies that have comprehensive instructions. If you have good newbie-oriented plans you shouldn’t need to ask these kinds of questions.
Dances with Turkeys
Old 04-02-2012, 11:29 PM
chriscrafter54 chriscrafter54 is offline
Rep: 10 Posts: 3
Go to Youtube and check out brandotown
Townsendboatworks. great vidios
Help for newbie kayak builder goanywhere Boat Design 17 03-24-2011 12:35 AM
a boat/moter/trailer buy for some boat builder. thudpucker Marketplace 0 11-06-2009 12:27 AM
Newbie to boat design and building wants to make own boat bigisland Boat Design 2 01-20-2007 01:03 AM
I'm looking for a boat builder David Dewberry Fiberglass and Composite Boat Building 0 08-02-2006 06:30 PM
All boat builder erkanyilmaz Metal Boat Building 0 06-20-2006 09:16 AM
