| Why a four blade? Use a three or even a two blade. |
| It came with the donor boat a 16 foot ski boat so if it worked for that it should work for mine plus I don't want to spend more money if I don't need to, I won't be racing this boat just messing about and spreading the sound of a V8 ![]() |
| Wow that looks like fun. |
| Just a quick update, the engine has had it's first test run ![]() And as we had a few good days of weather I went ahead with the fiberglassing just doing one side at a time I was able to give it 4 coats of resin with a 3 hour gap between each one. ![]() ![]() ![]() I kept all the overlaps below what I think will be the waterline where it will be painted. now let the sanding begin ![]() ![]() |
| Wow. Looks good. Keep posting.
| You are making great progress.
| First coat of primer I will sand this down with 600 paper and do two more coats and sand again. ![]() And first coat of paint "roll and tipped" I will do another 3 or 4 coats with a light sanding in between then on the last coat I will sand it with 800, 1000, 1500, 2000, wet and then rubbing compound. ![]() |
| I had to make up a new strut suit my angle. ![]() ![]() Just have to sink it a bit more and fiberglass the base and the prop tube that will hold the stuffing box. ![]() ![]() I always knew it would be tight to fit the rudder but I just might get away with it using a plate on it also I think I will recess it into the hull so it sits flush. ![]() |
| Paint looks KILLER! Nice Job! |
#25
#26
| Cheers guy's I still have to do another 3-4 coats after I fiberglass in the prop tube strut base and rudder hole then sand it with 1000-1500 wet paper then rubbing compound and wax to get a gelcoat look finish. ![]() |
#27
| I sold my donor boat shell so started to rebuild the trailer with new bolts,bearings,brakes,cables,tow hitch and so on won't be long now till the flip![]() ![]() ![]() ![]() ![]() |
#28
| Hmmm....I Never found the need to use 600 with paint ? Normally course paper...220 for primer, then 320 to 400 for finish coats. Working in the proper temp with the proper viscosity paint gives glasslike roll and brush . Carefull you dont develope an adhesion problem with such fine paper. |
#29
#30
| Ahh...sounds better. Occasionally I use very fine paper or scotch bright pads on touch up work. Last week I removed a piece of masking tape from a previous small touch up and the finish coat came off with the tape. Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.............................................. Beware of very fine paper,the tooth may not be sufficient . |
| boatbuilder | peter radclyffe | Wooden Boat Building and Restoration | 2 | 01-15-2010 11:48 AM |
| Who And What Is A Boatbuilder | Sean Herron | Open Discussion: All Things Boats & Boating | 47 | 12-30-2008 12:10 AM |
| Boatbuilder available | james barlow | Fiberglass and Composite Boat Building | 9 | 09-01-2008 02:40 PM |
| Boatbuilder Available! | Daniel Rogers | Services & Employment | 3 | 03-14-2007 07:05 PM |
| looking for boatbuilder | ikaros marine | Services & Employment | 1 | 08-17-2003 10:27 PM |
