| Need advise for removing varnish Is there a good way to remove varnish from a plywood boat? I emailed one company that sells stripper and they said it will make the plywood soft. Any help would be great. I attached two pictures of the boat I'm trying to remove the varnish from. Thanks for the advise received so far. Last edited by 58Dunphy : 11-21-2007 at 08:35 AM. Reason: Added Pictures |
| I don't know if this helps or not, but... Common carberator cleaner will remove varnish from a wood surface. How do I know? I was changing the registration numbers on my boat and I used carberator cleaner to remove the sticky residue from the previous letters that were stuck to an epoxy surface. It worked great for cleaning the epoxy surface. However, without thinking about it, when I had finished I laid the rag on my varnished deck. The rag, still damp with carberator cleaner, was left on the varnished surface for about 5 minutes. When I picked up the rag (now dry), the varnish underneath it had become dry and flakey. I simply brushed it away with my hand to expose the bare wood. I was amazed at how quickly the carb cleaner had disolved the varnish, but I guess that's what carb cleaner was designed to do. If I ever need to remove varnish, I'll just buy a cheap can of carb cleaner. Since it evaporates quickly, I don't think it will make the plywood soft. You might want to try a small, unseen test patch before using it in more visible areas. Oh, and I did have to revarnish the entire deck. |
| Carb cleaner will stain the wood considerably. There are several strippers available, but it's not the best way for clear finishes if you want to make them clear again. Unfortunately, scraping is the best and safest method. Sanding usually leaves the surface blotchy, especially when you get into the raw wood in some areas and not in others. Plywood has a thin outer veneer that also works against you, so aggressive sanding can go right through this outer veneer, which generally ruins a nice section of plywood. Plywood as a rule, doesn't look particularly good under clear finishes, unless it's a sliced veneer panel (not very common, as most are rotary cut). Strippers are good if you have a lot of material to remove, like several layers of paint or years of built up varnish. Generally you use the stripper to remove the bulk of the surface build up, then scrape it down to the bare wood. |
| I have had very furry results from using strippers. They almost always seem to damage the wood. I only use a hot air gun now and have done a number of major restorations and refurbishments with this single inexpensive tool and and some sharpened scrapers. Whichever way you go it is a lot of work.
__________________ my boat pages |
| Urethane vs Varnish | MarcD | Wooden Boat Building and Restoration | 16 | 01-15-2012 11:37 PM |
| varnish or epoxy | 2geekie | Wooden Boat Building and Restoration | 17 | 04-09-2008 12:16 PM |
| 64 Resorter varnish help please | H2Only | Wooden Boat Building and Restoration | 25 | 12-22-2006 12:20 AM |
| fiberglass over varnish | fiberglass jack | Fiberglass and Composite Boat Building | 3 | 10-12-2006 06:25 PM |
| Spar Varnish | dcoop | Materials | 4 | 03-22-2003 11:37 AM |
