| more information on boatbuilding needed Hello everyone I have plans to build an 8m yacht in plywood. I have no experience at all with boatbuilding but I'm quite handy and I transformed a lot of wood before. Also I will start with a smaller open sailboot to get familiar with it. I have som questions, mostly about connection smaller pieces of wood and finishing. If anyone knows a good book or website about this please let me know. My first question is how to connect smaller pieces of wood without loosing its strength. The Kavalier 800 I'm planning to build needs pinewood sticks (can't find the english word for "big sticks") of 800cm. As far as I know I can only get 400cm length. Thus I would need to connect 2 pieces of 400cm. How could I do this? Also the frames made of plywood are to big to get out of one piece. The pieces I can get are aprox. 122x244cm. These parts (as well as the pinewood parts above) are very important for the strength of the construction so the connection should be very solid. Then about getting it all together. Is it a good idea to screw te pieces together with some glue? At the end the gaps will need to be filled with epoxy, right? And finishing. Before getting al te parts together I think the wood should be entirely prepared to be water resistant. Then when assembled the outside needs to get a very waterproof finishing. What is used for this? Is it a kind of paint or more like epoxy? Any brands so I can look it up on the internet? thanks for any answers |
| If you're planning on building a plywood boat, I think a must read is this book. http://www.westsystem.info/gobronboco5t1.html Another is, http://www.devlinboat.com/order.htm , these should give you an excellent start. They will not make you a boat builder but educate you enough to ask more detailed questions. Welcome to the forum. ![]() Gary ![]()
__________________ "The hand feeds the mind." Weston Farmer |
| This is an excellent suggestion. Look also at: http://www.glen-l.com/ However the architect should specify the method of building and generally will be happy to give you any important information. CapKos |
| Visit my website at www.boatbuilder.org. There is information there on stitch and glue construction that may be usefull to you. ---Joel--- |
| Scafing, Scafing is what you are thinking of, beveling stringers and panels to glue them together, 1/8 ratio minimum, epoxy or PU glue. Butt straps, can be used but not so good on high performance boat as you plan to build. Seems like a very complex design perhaps try something simpler first, Yours James |
| Knowledge needed on composite boatbuilding | ethan1007 | Fiberglass and Composite Boat Building | 4 | 11-09-2005 10:57 AM |
| Future in boatbuilding | flajjer | Open Discussion: All Things Boats & Boating | 30 | 06-05-2005 02:16 PM |
| Information Needed | ussnautilus | Education | 2 | 05-17-2005 04:04 AM |
| how learn boatbuilding? | Education | 0 | 03-19-2003 01:17 PM | |
| boatbuilding freshman | Education | 0 | 10-15-2002 03:35 PM | |
