Old 07-06-2010, 04:04 PM
stonster stonster is offline
Rep: 10 Posts: 4
Modelling?
Hi all,
Rather new to the idea of boat building. Main challenge is persuading family it's a good plan. Anyway, here is my beginner question - sorry if it's been answered already! A few people I've heard suggesting it's a good idea to build a scale model of a boat before you build the real thing. Does this still apply to stitch and glue boats, even if you've got the design from a book? And has anyone done it? Did it give you motivation, or just run you out of energy?
Thanks!
Old 07-06-2010, 04:19 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Hi Stonser, welcome aboard the forum.
Yep, a model is a great starting point. It's not always necessary, but is usually fun and rewarding.
Why not? If you're buying plans, there are probably other boats of that class around, so you know it'll work. But there's nothing wrong with mocking it up yourself if you're so inclined.
I built a 1:12 model of my Phil Bolger runabout before starting the full-size version. Despite being a simple taped-seam design, the model was worth the time (a day or so) it took to make, and it gave me a good idea of what to expect when bending the full-size panels into shape.
Old 07-06-2010, 05:12 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
I made one of simple bristol board (card) stock. As Matt said it's a good exercise. I wish I had the metric plans though, makes scaling easier!
I've also modeled the boat in Google Sketchup for fun. That's cool, allows you to move things around, get a feeling for the accommodations before you even build the boat. There is a model of a DE25 (IIRC) on the bateau.com site somewhere.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 07-19-2010, 11:46 AM
Rep: 10 Posts: 4
thanks for all your tips.
Any thoughts on balsa v thin ply v card? I quite fancy thin ply because then at the end of the day you have a nice model to keep...
Old 07-19-2010, 12:07 PM
Rep: 578 Posts: 615
Good choice.
Old 07-19-2010, 02:02 PM
gww25 gww25 is offline
Rep: 10 Posts: 16
Back in the old days it was almost a requirement that designers and even builders build a scale model of their proposed projects. I guess this has kind of gone out of style but I was taught to always build at least the rudimentary structure of the boat before going into full scale construction.
I still think it's a good idea even today.
Old 07-19-2010, 02:39 PM
marshmat's Avatar
I've tended to use card stock, simply because it's cheap and everywhere. But I'd rather use thin ply (for developable shapes) and foam or balsa (for compound shapes). Card stock doesn't stay fair for long once you start working with it.
Old 07-21-2010, 03:45 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
My earlier habit of building a model has been replaced by the use of hull design applications such as FreeShip, which will provide plank developments and other useful data. Of course you ned to start off with the hull lines.
Dances with Turkeys
Looking for work, 3D modelling and rendering. isvflorin Services & Employment 13 06-14-2010 05:38 PM
Ergo/Anthropometric Modelling sibosun Boat Design 0 06-04-2009 05:44 AM
Planing hull modelling national Software 9 02-20-2007 04:13 PM
Sea Surface Modelling weaviestevie Boat Design 3 11-11-2004 09:04 PM
Photorealistic 3D modelling!! StreamWork Services & Employment 5 08-21-2004 11:07 AM
