Old 02-13-2008, 05:40 PM
kayakn kayakn is offline
Rep: 10 Posts: 22
mirror dinghy?
i am working on a 1974 mirror dinghy and i am wondering what thickness the wood is on the front bow cover? the piece above the front deck and the front panel.
thanks.
Old 02-19-2008, 09:26 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
You would get that exact info from the Mirror Association in your area, but from memory on my mirror some years ago it was 5 mm (3/16")
Anything less would be a danger of putting a foot through it I suppose
Old 02-21-2008, 03:02 PM
Pete Dennison Pete Dennison is offline
Pete D
Rep: 10 Posts: 17
My Mirror tender is 5mm!
Old 03-03-2008, 08:01 PM
Rep: 10 Posts: 22
is the front piece it braced? i am just about finished with the boat. i put about 1/4 inch mahogany on the front and it seems ok.
the boat belongs to the sea scouts and i am working on it because i am a member. it was in bad condition. the wood on the bow and stern was rotten and so was some of the rubrail. i replaced the wood and then had to strip the paint completely because all of the paint was flaking off. i re-fiberglassed all of the corners because it was falling off. i put two coats of primer and about five coats of HMG paint on it. the inside was not in as bad condition but i had to make a new centerboard because the original had snapped in half. i sanded it down and re fiberglassed the bad spots. i put about five coats of HMG varnish on and it shines like new! i took the hardware like the hooks and rudder hangers and shined them up. i replaced the piece that goes on the front and made the centerboard and the reinforcing plate that goes on the bow all with mahogany plywood. the boat looks very nice now and i am amazed with how it turned out because this is my first boat. my next boat that i get is an Optimist Pram from the seascouts that i get to keep.
Mirror 16 foot Sailing Dinghy goolawah Wooden Boat Building and Restoration 217 01-23-2012 05:36 AM
construction drawing mirror dingy sass Boat Design 6 10-16-2009 04:59 PM
Hull Ident # - mirror labeling for GRP hulls? User_U Boat Design 22 05-28-2006 01:39 PM
Do I need to use tape on the joints of a mirror? DMShone Materials 3 07-08-2005 01:00 AM
mirror finish on mould mikeskip Fiberglass and Composite Boat Building 6 09-04-2004 04:55 PM
