  #211
Old 11-28-2011, 04:22 PM
Phanou Phanou is offline
Rep: 10 Posts: 4
2D shape
I am very impressed by the work you are carrying out in order to create a 3D CAD model.
Good news for the community, that once your work will be achieved you would make the plan available.
Alternatively as the Mirror 16 is a plywood developable hard chine construction, I am wondering if it will not be easiest to draw/copy directly the 2D shape of each pieces of the “puzzle”.
It could be done by laying sheet of paper on the chine and cutting or drawing along the contour line.
  #212
Old 11-28-2011, 04:36 PM
Ozducati's Avatar
Ozducati Ozducati is offline
Mirror 16 #189
Rep: 10 Posts: 40
The reasons that I want to measure the hull are for reference when assembling the new hull, and to confirm that the existing hull meets the Class Measurement rules.
I will be tracing templates however the bottom panels are badly damaged and distorted so I am not confident that I could trace a correctly shaped template.
I want to capture as much dimensional data as possible because once I pull the hull apart all that information will be lost.
Once the model is complete it will make it much simpler to create plans and dxf profiles for laser or waterjet cutting.
Rod.
  #213
Old 12-03-2011, 07:46 AM
Rep: 10 Posts: 4
I understand that you wish to be as accurate as possible.
Sometimes it's hard to figure out which rule to apply, "The devil is in the details" or "The best is the enemy of the good." Anyhow, I don't understand to which Class Measurement rules you are refering.
  #214
Old 12-04-2011, 12:46 AM
Ozducati's Avatar
Mirror 16 #189
Rep: 10 Posts: 40
Mirror 16 Class Measurement Rules
The measurement rules I am referring to are the Class Measurement Rules for the Mirror 16, attached.
Rod.
  #215
Old 12-04-2011, 02:56 AM
Rep: 10 Posts: 4
Thank you so much.
Stephane
  #216
Old 12-14-2011, 04:09 AM
Ozducati's Avatar
Mirror 16 #189
Rep: 10 Posts: 40
Hull measurements
Hi All,
I have finished measuring the external dims of the hull. I have attached the results as a table, and a dxf with the points connected. The dxf points are in 3 dimensions so if you have suitable cad software you should be able to rotate the viewing direction. In the dxf you can see the distortion of the keel due to age and rot. The points on the keel are measured on the lower face of the 3/4" timber strip that runs along the keel.... I have now started to remove that strip so that I can take templates of the hull panels.
I found a rustly block of steel about 6" x 2" x 1" lying loose inside the rear portside flotation tank!!!???
Its slow progress but I'm getting there.
Mirror 16 foot Sailing Dinghy-img_4084.jpg  Mirror 16 foot Sailing Dinghy-img_4085.jpg
Rod.
  #217
Old 12-28-2011, 10:58 PM
mirror 16 mirror 16 is offline
Rep: 10 Posts: 2
small rebuild....
Hi all,
well 261 had a few problems too. The bottom was disconected from the frames in a few places, the transom was rotten in the corner, the previous patches leaked and well it was time. so last winter off came most of the bottom and on went new frames and a new bottom and transom. all went well. the camping picture is from this september we went on a 4 day cruise up the coast to pender harbour for the jazz festival and then sailed home.
keep up the good work
dan
Mirror 16 foot Sailing Dinghy-img_3402-small-.jpg  Mirror 16 foot Sailing Dinghy-img_3775-medium-.jpg  Mirror 16 foot Sailing Dinghy-img_3747-small-.jpg
  #218
Old 01-23-2012, 05:36 AM
Ozducati's Avatar
Mirror 16 #189
Rep: 10 Posts: 40
The rebuild looks great Dan!
Did you make the new ribs the same as the old ones or did you beef them up?
Rod.
Sailing Dinghy Poll mackid068 Sailboats 28 12-27-2011 12:20 AM
D4 / D5 Sailing Dinghy dominic Wooden Boat Building and Restoration 3 09-15-2006 05:42 AM
Mahogany Alternative for sailing dinghy? dcoffey Materials 1 04-08-2005 04:16 AM
Sailing Dinghy Design Tim B Sailboats 368 12-15-2004 07:46 PM
