Old 12-21-2009, 12:57 AM
Archie1979 Archie1979 is offline
Rep: 36 Posts: 57
Hi again everyone,
I have a question and need some advice:-
I am looking at possibly installing some planing chines on my hull and not sure if it is a good idea or not as they are not in the original design plans. From what I do understand however is that the planing chine will allow a small savings in fuel and require less power to get onto the plane.
ie as the surface area of the planing chines is less than the hull on its own creating less drag through the water once up on the plane.
I am just trying to find some good article on this subject and I dont want to waste my time on these chines if I am not going to get any REAL benefit out of it.
Advice is most welcome
Oh yeah I forgot to add I will be installing the Volvo Penta QL Automatic Trim tabs so would these chines be necessary
Archie
Old 12-21-2009, 10:10 AM
Rep: 3125 Posts: 9,403
If I remember correctly your hull is a typical warped bottom. You can install strakes if you want, but you will not appreciate, nor notice much difference between a hull without, compare to one with these. Your warped bottom will quickly get up on plane, because she has a moderate amount of deadrise aft. Any improvements will be very slight with strakes. I also think you should wait to install the trim tabs, as the boat should "run out" will engine trim fairly easily.
Old 12-21-2009, 01:38 PM
Rep: 36 Posts: 57
Thanks Paul i'll give them a miss and wait until she is completed to see if I even need the trim tabs.
Archie
Old 12-23-2009, 02:51 PM
Rep: 36 Posts: 57
Hi Everyone
Just a quick question you may be able to help me out on, I am completely confused when it comes to boat trailers. Do I opt for a trailer with keel support like an aluminium boat trailer or do I go for something more designed for a fibreglass hull.
Mine is obvioulsy a wood/fibre/epoxy hull and I dont want the trailer to ruin my boat.
Archie
Old 12-23-2009, 04:47 PM
Rollers for the keel, never rollers for the planking on a wooden boat, regardless of construction method. It'll just test all the seams and fasteners pull out strength, eventually causing issues. Bunks are effective if the boat is to remain on the trailer a lot, but they should just keep the boat from flopping over, not push up hard into the planking. The boat should rest on the keel and not it's bilges. Use as many keel rollers as possible, the more the better.
Old 12-23-2009, 06:50 PM
Rep: 36 Posts: 57
Thanks again as always
OH and by the way
Ho HO HO
MERRY CHRISTMAS
Old 11-10-2010, 08:44 PM
Rep: 36 Posts: 57
Hello Everyone,
Well its been way too long since I have posted about my boat. Progress has been really slow since my last post. I had a work injury which needed surgery and have had my spine fused and have just been told by the doc today that I can start to slowly do normal things again.
Sooo that means back to the shed. wooohooooo
anyway I though I would do a quick message just to let everyone know that I am still constructing my beauty but it has just been taking a bit longer than I first planned.
The joys of boating hahah
When I get down to the shed I will take some pictures so everyone can see where I am at.
Old 11-11-2010, 11:14 AM
These once a year posts are hard to keep up with Archie. Glad you're on the mend. Did you get a trailer?
Old 11-11-2010, 05:06 PM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
Sorry to hear of your troubles Archie but glad to hear that you are on the mend. Be careful around your boat and take it slow at first.
Good Luck,
MIA
  #25
Old 11-14-2010, 02:08 PM
Rep: 36 Posts: 57
Hey Paul & MIA,
Thanks for the replies, yeah I know once a year posts arnt much use to anyone. Now that I am fixed it wont be long until my baby can be flipped.
As for the trailer I was injured shortly after that post so no headway on that just yet, but like I mentioned back on my feet again now and things will now happen pretty quickly.
Its a good time for us Aussies to import engines too so I might look at that whilst the dollar is up.
thanks gents, chat later and I will post some pics this afternoon once I finish spraying the undercoat.
Archie
They'll have you coming and going. Pericles Open Discussion: All Things Boats & Boating 2 03-09-2008 05:37 PM
Stop water coming through hdragon Boat Design 3 03-04-2006 03:18 AM
My canoe is coming along Ward Boat Design 12 09-03-2005 01:28 PM
Angle of waves coming off the hull netjaws Boat Design 3 01-25-2004 03:04 PM
Speed Limits Coming??? sharkeymarine Powerboats 12 03-06-2003 10:48 PM
