Old 08-18-2004, 11:00 AM
byankee byankee is offline
Rep: 14 Posts: 47
meranti for sawn frames?
Any thought about the suitability of dark red meranti (AKA Phillipine Mahogany) for use as sawn frames, stem and chine material in a traditionally builit (i.e. copper fastened, solid wood lapstrake - no epoxy, no plywood) skiff?
Old 08-25-2004, 12:25 AM
Rep: 572 Posts: 646
It seems that nobody wanted to answer to you: dark red meranti is suitable for your uses. In Philippina it is common wood. You can use also Light red meranti wich has a better ration strength weigth if I remember well.
Old 08-25-2004, 05:48 PM
BIG MAC BIG MAC is offline
Rep: 10 Posts: 12
splinters
Meranti and Luan are both inferior to true honduras and phil mahog. they have stringy course grain and are very splintery. spend a couple of more bucks and get real mahogony.
Old 09-01-2004, 10:20 PM
MARLAB MARLAB is offline
Meranti
I have been building my prototype hulls in Light Meranti these last 2 years and I have to say that I should have started doing so earlier, It is a very forgiving material to work with and once epoxied is very strong even in thinner plates. My latest boat for example is a 19 foot catamaran power boat for remote control and uses sawn Meranti bulkheads (with a jig saw) 15mm thick and a skin only 6mm thick. So go ahead with either light or dark Meranti, you won't be disappointed if you treat the material with respect.
Gerry
Old 09-10-2004, 05:16 PM
pungolee pungolee is offline
Rep: 34 Posts: 90
I would use white oak or locust or longleaf pine or true hackamatack stump wood for the stem,you dont need no light stuff here.Make it tough as possible,the rest will take care of itself.
Old 10-21-2004, 02:55 PM
nero nero is offline
Rep: 112 Posts: 624
Does anyone have a source for Light Red Meranti and Dark Red Meranti in the U.S.? I would like 3,000 bd ft of LRM at a cheap price.
Thanks
Keel And Frame ? MACINAW Metal Boat Building 5 05-05-2005 12:20 AM
Jig for laminating frames? Mohan Pakkurti Wooden Boat Building and Restoration 8 02-10-2005 06:22 PM
Meranti ply specs? Phil Locker Materials 16 01-02-2005 06:40 PM
Backwards frames on 16 ft Runabout runabout Boatbuilding 3 10-07-2004 09:24 AM
Floating frames Morgig Boat Design 2 02-13-2004 04:03 PM
