Old 02-08-2012, 03:06 AM
Roly Roly is offline
Rep: 222 Posts: 490
Machining lead......
I have researched this on line but only come up with cnc driven systems with
no reference to tool bits, rpm, etc.
What is the low tech method to cut a 180x250x10mm deep rebate in the side of a lead keel?
My power saw has cut the outline to 10mm deep and I tried chiselling but it is
really tedious. I was temped to rout it out but was told it would gaul the bit up in no-time flat.
I guess I could run the stilsaw at 25mm intervals and use a power chisel?
What about melting it out with the gas axe or lpg torch? Could be a bit hard to control tho'.
Old 02-08-2012, 03:22 AM
Rep: 670 Posts: 2,457
Lead is soft and easy to cut. Ive used a sharp electric chain saw to shape lead keels. Keep the blade sharp and lube oil pumping. A router also works for small projects. Powerplanes work well on lead
Your skill saw way is good. Perhaps tack a batten to the keel and keep making cuts and kerf it all away. Clean up wih a router. I used no special router bits and a normal plunge router.
Ive never tried a blow torch...sounds messy.
Old 02-08-2012, 12:56 PM
Rep: 324 Posts: 591
Roly
I've run into this problem...my solution was to buy one of those $35 air chisels and buy some extra flat blade bits. Sharpen them with a steep edge angle on a grinder. You need plenty of compressed air. (at least 10 CFM)
Old 02-08-2012, 01:18 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
I cast drafting "ducks" in lead when I was a teenager and had problems drilling the holes for the wire finger. The drill bit tended to grab. Off to visit an elderly but very talented machinist who was a family friend. His solution was to regrind the tip of the drill bit so it was flatter and more scraping more than cutting. Worked great in the lead.
David Cockey
Old 02-08-2012, 03:42 PM
Nick.K Nick.K is offline
Rep: 60 Posts: 111
Try with a router, if possible with a half inch chuck and variable speed on lowest speed. Do it in several passes. Attach a plate to the base of the router if it has a tendency to fall in to the hole. If the keel surface is not flat, attach another plate to the keel to run the router on.
I have used a lot of lead bar for sash window weights, apart from cutting it to length on a chop saw we would some times run it through the bandsaw for a lighter section. Never had any problems except build up of lead on the teeth that could fly out dangerously. Stop to clear regularly and when you feel vibration.
Melting it with a torch sounds like a recipe for lead poising from vapour.
Nick.
Old 02-08-2012, 05:46 PM
Rep: 3125 Posts: 9,403
Most power tools will gaul, because of the speed at which they spin. Reciprocating tools are less prone to this and if used with a large tooth (low tooth count), they can spit out offending bits, before they can cause issues. Lubrication is necessary and oils are typical, though some still use kerosene, which isn't wise with power tools, but fine on hand tools.
The lead type (composition) also makes a big difference. If cast with antimony, up to 7%, but typically just a few percent, will make machining much easier.
Also freezing the lead can help a great deal. Spraying the rabbit line with A/C refrigerant or other really cold stuff, saves the bother of packing your freezer full of ballast casting. You'll need to do this repeatedly along the cut's length (every few feet).
The basic rules are low RPM, lots of lubrication, a high feed rate with very aggressive tooth patterns. A mutli tool may be useful on this. If you slow down, the bit or tool teeth will clog and gaul in the kerf, if you have too much RPM, the same, ditto high tooth counts and insufficient lubrication.
PAR Plans
PARBlog
Shrinkage of Lead Sam III Fiberglass and Composite Boat Building 43 11-07-2009 07:29 PM
Machining Composite Matierial? westsail42 Fiberglass and Composite Boat Building 3 05-23-2007 08:48 AM
Lead Bulb matalag Boatbuilding 7 06-26-2006 11:10 AM
cnc machining cerberus Boatbuilding 4 03-31-2006 09:53 PM
Prop Shaft Machining Asia Help Game-Fish-Asia Propulsion 3 04-25-2005 04:43 AM
