Old 02-18-2005, 04:10 PM
doesitfloat doesitfloat is offline
Rep: 10 Posts: 19
Longer Cedar strips
Planning a 30 ft boat with cedar strip construction. Would like to make 30+ ft strips. Make the whole thing go faster. Wondering if anyone knows of a woodworking machine that makes the lap joints to glue strips together(length wise).
Thanks for any feedback.
Old 02-18-2005, 07:23 PM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
The common table saw does nicely. Set the straight cut guide about 18" away from the blade. Lay the marked strip against the blade while stopped. Cut a piece of trued, thru a planer, piece of 2 X 6-8-? . Cut it to fill the space between angled wood and straight guide. You can keep the filler strip in place by double sided tape-blocks and C clamps- etc. The wider the filler piece the more strips you can cut at once. You may want to go to a lumber mill and have them cut a tree in RIFT CUT only to get all strips with ALL the correct grain direction for bending the long strips. Just remember to keep all the grains the same or change them as the hull curves dictate them.
Old 02-20-2005, 09:51 PM
Rep: 1493 Posts: 7,447
For a faster job, don't worry about the total length. Cut the strips square and let the buts have at least three planks in between.
Old 02-21-2005, 12:59 AM
Rep: 3125 Posts: 9,403
Gonzo is right, it's not faster to have full length strips, in fact you'll break more then you install, if trying to handle over 30' pieces of cedar. Rip, strip, butt, strip some more and stagger your joints well. This is the fast way and the whole point to this construction method.
Old 02-21-2005, 08:58 AM
Rep: 10 Posts: 19
Thanks that helped.
59" 1/4 scale canoe/built with purplehart timbers and white cedar hull. Littlebearcanoe Boat Design 5 09-08-2005 07:07 AM
Michlet available again (but no longer free) Jeff Software 4 07-25-2005 01:20 PM
Use of eastern cedar end-grain for core jfblouin Fiberglass and Composite Boat Building 1 12-05-2004 02:04 AM
Western Red Cedar winni Materials 2 09-05-2004 08:39 AM
Western Red Cedar, fir for sale. Long and some big. alteran Marketplace 2 04-08-2004 01:11 AM
