Old 10-22-2007, 02:51 AM
layout layout is offline
layout boat
question
I am building layout boat for Duck Hunting shallow water. Like a rice field. Anyone see a problem with making my boat 8' and not 10' as the plans say?
I'm about 160 lbs.
by the way my first boat
Thanks for any help
Old 10-23-2007, 10:39 PM
lewisboats's Avatar
Obsessed Member
Rep: 373 Posts: 1,062
yes...it will sink deeper into the water. I would need to see the dimensions of the boat before being able to tell you how much. Seeing as a layout boat is designed to sit just at the surface...I would not be surprised if it swamps with the reduction of buoyancy
Steve
Old 11-08-2007, 05:55 AM
dimitarp dimitarp is offline
Rep: 19 Posts: 89
layout boat
You can find full plan for layout boat at:
http://www.partenovcfd.com
Old 11-08-2007, 08:28 AM
alan white's Avatar
Rep: 590 Posts: 2,640
Stick to the original plan if you can. Small boats are usually designed to close comprimises. You can't change one dimension without changing another except when going bigger. Going smaller, the entire boat will have to be redesigned or lose important safety and performance factors.
Making it shorter you could make it wider, I suppose, which will make it a slug in the water. If you went deeper, you'd decrease the very factor that the boat is intended to accentuate---- shoal water use.
By what you describe, cutting two feet off would mean the boat would be suddenly incapable of carrying a second passenger of your weight along with you. Quite a difference!
Alan
Iam looking for plans for a "layout" boat MP Sniper Boatbuilding 6 10-12-2009 11:32 AM
Bare Aluminum Boat- Need Help Starting Electric Layout wfcperrine Electrical Systems 6 03-01-2009 10:02 AM
foredeck layout pengreg Sailboats 3 05-05-2005 06:49 AM
can anyone one help for manu. layout mechatics Fiberglass and Composite Boat Building 2 04-20-2005 12:10 PM
Deck Layout nemo Sailboats 5 09-28-2002 08:38 AM
