| A Layman's question... Hey folks. My name is Steve Vernon and I'm a Nova Scotia writer. I am looking to pick your brains here regarding a question about boat repair. Hope you can help me out. A character in my novel is attempting to repair an old-fashioned wooden dory, the kind built like the old Viking longboats, (lap built, I think they call that?). The dory has been holed by an errant caber toss. How would the fellow who built the dory in the first place go about making his repairs? Steve Vernon |
| The Viking boats, ships, were built with full length planking carved to shape rather than bent to shape! This meant using large trees and only getting a few planks for each one! The stem and stern and keel where built first, then the planking was added, because they were carved to shape they required little internal framing, the curve being the strength of the hull. They were fastened with pegs and copper rivets! Repair was just to remove the fasteners, make a new plank, install and be on your way! They were more than mere sailors or warriors! They had to be to survive! |
| Most dories uses a unique construction method, called the dory lap (along with other elements) and generally are called dory built. Had she been holed, the repair may take on several different approaches, depending on where it was holed. Typically a "scab" would be scarfed or butt blocked into the damaged plank. If more then one plank was affected by the damage, the separate plank repairs would stagger the seams of the scarfs or butt blocks, as to not make a weak area on the side of the boat. Of cours,e dory as well as Viking building techniques evolved over the years, incorporating things learned from previous generations and to address nagging issues. The repairs would also show a similar development curve, based on era, repair skills and budget. |
| Thanks kindly. I do, of course, have to do some homework on my own, but this is damned helpful. Keep it coming. ![]() |
| Now - is this book a comedy? If so, the guy could be completely inexperienced in woodworking, so the most amazing problems could arise. If not, maybe he is a lawyer, and he could sue the kilt off the caber tosser. A caber would fall across the boat usually, crushing the thwarts - or did it drop straight down through the floor - in which case it was possibly done on purpose. Give us a bit of background here now - like how the hell did a caber get anywhere near a dory ?. |
| It's meant to be comedic. The caber throw was just plain bad aim, and it did (as I see it), impale the dory. The fellow who is re-building the dory owns it, and also chucked the caber. He ought to know a bit about dory building - but probably not as much as he thinks he knows. |
| I would saw the caber up to make planks for the repair to teach it a lesson for a start. Make sure he quarter saws the log to make the planks. |
| Damn, rwatson, that's a great idea. Only the caber has been out in a backyard for way too long and is probably too dry for that sort of thing. Still, it might make a make-shift mast... |
I should tell you folks that I have had a couple of maritime books published in the last few years and I'm certain I can get this one out to print as well. I will make sure to thank everyone here in the dedication department. So far, your advice has been invaluable. ![]() |
| He ought to know a bit about dory building - but probably not as much as he thinks he knows. Isn't that so true ......
__________________ It ain't fishing if you ain't using a lure |
