Old 03-23-2009, 08:05 PM
garren garren is offline
Rep: 10 Posts: 20
Lapstrake multi-purpose "canoe" plan options
I've researched the archives and the internet and have not found a satisfactory boat plan that seems to serve my intended purposes. Maybe it doesn't exist.
I live beside a small lake in Billings, and the Yellowstone River (class 1-2+) flows through town. There are many other lakes and rivers (class 1-2+) within a couple of hours. I want to build a "canoe-like" lapstrake boat that can be paddled efficiently by two on lakes and "rowed," driftboat-style, on rivers. I think that means three seats - one for each paddler and one near the middle for rowing.
Is there a plan for such a beast? How wide must the beam be to accommodate oars? I'm thinking 14-16' range and hopefully less than 100 pounds.
I am an amateur woodworker and have an adequate supply of power and hand tools. I have canoed a bit on rivers and lakes and have rowed rafts and driftboats on larger, class 3-4, rivers.
I would appreciate any links or references to plans and ideas on accommodating these two purposes with one boat. Any other advice or information would be appreciated.
Gary Davis
Old 03-24-2009, 12:45 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
You may find something that will work for both. But not very well. Drift boats have a lot of rocker and are wide. C2's have little rocker and are narrow.
"The hand feeds the mind."
Weston Farmer
Old 03-24-2009, 10:19 AM
aka Terry Haines
Rep: 1682 Posts: 2,811
Did you mean a drift boat or just a regular rowing boat? A drift boat resembles a dory and intended for use on a fast moving river, nothing at all like a canoe. If you build a canoe, i.e., long and narrow, it is too narrow for rowing but it can probably be fitted with outriggers like a rowing shell. But like the mustache says, it might not do either job very well.
Dances with Turkeys
Old 03-24-2009, 10:47 AM
alan white's Avatar
Rep: 1168 Posts: 3,269
Sounds like a long and narrow rowing boat, something around 17 ft and 3 ft beam. There are many out there in lapstrake. Try Tom Hill, Duckworks, and google fast rowboats.
They are very canoe-like, but to be narrow they usually use outriggers to row. Usually easily detached.
Old 03-24-2009, 02:25 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1298 Posts: 1,991
Check up Amazon river, Loadum up
Old 03-24-2009, 10:08 PM
Wayne Grabow Wayne Grabow is offline
Rep: 260 Posts: 139
I tried designing a boat like you describe; I wasn't successful. To row you need about 40" beam; to paddle you need a narrow beam and tumblehome is helpful. Have you considered an Adirondack guideboat-type design? They are row only but very fast, easy gliding, light, maneuverable, and carry a good load. I built one of those and have been very happy with it.
Old 03-26-2009, 01:05 PM
Rep: 10 Posts: 20
Thanks all for the advice. I'm looking at adirondack guideboats and a couple other designs. Any other advice is appreciated.
Gary
16-18' "Sit-in" Planing Monohull ("Trapwing") Doug Lord Sailboats 124 04-23-2009 06:14 PM
CMD "project Zeus" VS VOLVO "IPS" gerard baladi Pod Drives 13 09-10-2007 10:23 PM
Boat "workshop" including a "testing tank" zmfmd Open Discussion: All Things Boats & Boating 0 08-08-2007 05:43 AM
Tri-purpose "Micro-Cat" concept VBAjedi Boat Design 3 10-22-2004 09:06 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
