Old 11-05-2011, 02:30 PM
Corley Corley is offline
epoxy coated
Rep: 524 Posts: 632
kokoda marine ply has anyone used this for hull construction?
I'm currently preparing for a project that will require the lightest ply possible.
I'll be buying a pallet of ply and choosing only the lightest sheets the pricing for this ply seems reasonable and its about as light as I can find has anyone used and have any comments on this ply? I'm wondering what the surface is like if its quite rough I'll probably pass on it and use gaboon as the weight stacks up quickly with fairing.
Old 11-05-2011, 05:10 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,026
First I've heard of, does it come from PNG? http://www.internationalpanels.com.a...%20Grade%20Ply
Old 11-05-2011, 08:34 PM
epoxy coated
Rep: 524 Posts: 632
Theres some discussion on the forums at diy-yachts.com the general consensus is its similar in properties to gaboon and a bit lighter but there seems to be more variation between sheets. Yes thats the type linked on International Panels. Pink Satinwood is the material used for the veneers it seems couldn't find much data on the tree or its properties.
Old 11-06-2011, 08:07 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,401
Everything I have heard is good
Light Weight Plywood
Contact Mark for an in depth explanation of plywood virtues at
http://bowdidgemarinedesigns.com/Bow...ontact_Us.html
Fibreglassing a marine ply hull - costs kitkats Boat Design 25 09-03-2009 06:44 PM
Ply construction - Interior finishing. Trevlyns Fiberglass and Composite Boat Building 2 04-20-2007 06:51 AM
marine ply longliner45 Marketplace 4 10-22-2006 06:51 PM
Marine ply 30ft Yacht, Hull OK- Cabin Needs Repair hansp77 Wooden Boat Building and Restoration 0 03-28-2006 05:12 AM
Wet Marine Ply chas underhay Materials 6 11-15-2005 07:33 PM
