Old 11-03-2010, 04:54 PM
Psuedomonas's Avatar
Psuedomonas Psuedomonas is offline
Psuedomonas
Rep: 10 Posts: 20
joining plywood with puzzle joints???
I will soon be making 1/4" plywood into 16' lengths. Previously I used a common scarf joint, but with only 1/4" to work with, these are not too strong. Can anyone suggest a method or router jig to make interlocking joints across a 48" surface?
Old 11-03-2010, 05:24 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
here is a link on a method I'm going to use. I only need to buy the bar pattern and use lots of epoxy.http://www.duckworksmagazine.com/06/...zzle/index.htm If you break the joint between frames you could put a but block out of ply on the inside or use regular wood. That wiil insure greater strength then the regular ply offers.
PS Where did you buy your wet exhaust manifolds for the subi engines? Did you make them? Stan
Old 11-03-2010, 07:16 PM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
At the recent Wooden Boat festival I saw that Chesapeake Light Craft is using puzzle joints on their kit boats. It seems to be a good way to join them. I suppose the difficulty is cutting out the joint.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 11-03-2010, 07:29 PM
wardd wardd is offline
Rep: 443 Posts: 925
you could take a 4' long piece of 1/4" thick steel as wide as 2 templates plus holding stock to a shop that has a cnc wire edm machine and they could cut it in half forming two interlocking templates perfectly matched
liberty ships were beautiful
Old 11-03-2010, 08:03 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
In case you still prefer scarfs:
A quick note to say that scarfing even 3mm (3/32nd of an inch) plywood is a breeze if you do the following:
Take every piece of plywood you want to scarf and stack them on a table, staggering them the appropriate (12:1) distance in a stair step pattern. (about 1.5" step for 3mm plywood)
Carefully clamp down the plywood to the table so it doesn't move.
Use a good low-rpm buffer/polisher with a sanding disc attached and sand that stair step into one smooth, uniform surface.
Follow up with a palm sander to get things perfect.
PRESTO! You can get perfect 12:1 scarf joints even on 3/32" plywood.
I did it this way and was able to put a perfect 12:1 scarf into 18 sheets of 3mm ply - taking about an hour for all 18 sheets. I did 144 sheets total, scarfs on all 4 sides, in about a week's time.
Was a hell of a good way to do scarf joints, just in case you still want to do them.
Kurt Hughes was right about this place.
Old 11-03-2010, 08:09 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Why not just learn to make a scarf joint. Its not hard to do and is the best of all such methods. 1/4" scarf joints are routine. 1/8 is a bit harder but still not too difficult for any reasonable woodworker with opposable thumbs. Locking joints are easier in many instances for assembly of CNC kits but are more difficult to make with ordinary tools and generally weaker.
Tom Lathrop
Old 11-04-2010, 03:30 AM
Rep: 670 Posts: 2,457
they use a finger joint in some kayak construction methods...dont know how practicle it is for full size sheets...have a look here
http://oneoceankayaks.com/stitchglue...carflock3b.htm
Old 11-04-2010, 07:41 AM
Rep: 3125 Posts: 9,403
Bingo Tom, the usual choices of finger joint aren't especially easy to make with hand tools, aren't very attractive and are generally weaker then a scarf. A 6:1 or 8:1 scarf ratio in 1/4" ply, with epoxy is well past stronger then the plywood itself, so I'm not sure why there's an issue,
If there's a strength concern, it's not the physical properties of a properly done scarf at these ratios.
As has been mentioned, a scarf isn't particularly difficult to make. You can eyeball one fairly well with epoxy or use a jig, of which there are many types.
Conversely, a Payson butt joint makes the scarf irrelevant. If the Payson joint is hollowed out and done under clamps, then it's about as simple as they get.
Old 11-04-2010, 07:52 AM
Paul, I consider a simple scarf easier to make than a Payson butt joint if the joint is to be well faired out on the surface. I sometimes use the butt joint with tape on both sides without the hollowing and fairing if the joint is in a non stressed area and fairing is not an issue.
Tom Lathrop
Old 11-04-2010, 11:26 AM
I too consider the scarf easier and considerably faster then the Payson butt joint. I do like the extra length you can get from the Payson joint and more importantly the nearly flawless faired result, with some setup on the hollowed version. Alignment issues are avoided with the Payson as well. This said I can hack out a good scarf in a few minutes and have it waiting for a cure in a few minutes more.
Old 11-05-2010, 12:09 AM
lumberjack_jeff lumberjack_jeff is offline
Sawdust sweeper
Rep: 99 Posts: 91
A scarf joint is stronger, but one disadvantage is that a scarf creates a "hard spot" in the joined hull panel that will sometimes come out unfair.
West Satsop Boatworks
Old 11-06-2010, 08:27 AM
Psuedomonas
Rep: 10 Posts: 20
OK guys- you convinced me. I'll stick to the old scarf joint, but I'll try Catbuilder's method of stacking. Many thanks for the input
Old 11-06-2010, 09:57 AM
To make a conventional slash scarf you need a good work surface to cut the scarf on and to glue up. Spend some time building a work surface. Hand planes, powerplanes, grinders, circular saws all will accomplish the task if you have a good work surface. By the way all the scarf techniques...Payson , conventional, fingerjoint have value according to the need. Those finger joints look great when naturally finished.
Old 11-11-2010, 06:14 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,918
I like it its neat and because the fingers are short and long and are staggered it will be much stronger than the ordinary finger joining in a straight line that would break along the dotted line so to speak , but with staggered fingers makes it much better !!!!
Making beautiful boats is a passion never a chore !
Old 11-11-2010, 07:43 AM
All the joint ..scarf techniques, have value. Its very difficult to pull off a scarph in plywood that will be bright finished. Very precise technique and skill is required if you expect to have a razor thin transition between sheets. That finger joint looks good. Id love to learn how to perform it.
joining plywood with puzzle joints??? Psuedomonas Wooden Boat Building and Restoration 0 11-03-2010 04:50 PM
Joining plywood to cast iron keel in an old Thunderbird Hercules Wooden Boat Building and Restoration 12 01-07-2008 08:06 PM
Prop puzzle ejfla Outboards 4 07-05-2007 05:10 PM
Rigging puzzle messabout Sailboats 8 05-20-2007 11:38 AM
Joints in bright-finished plywood WoodButcher Wooden Boat Building and Restoration 7 01-18-2005 08:30 PM
