#31
| If you laser cut your plywood, you can have any kind of splice you want. Fingerjointed, PuzzleJointed, horizontal joint, follow-the-woodgrain joint, whatever. If you find a 6-axis laser cutter, you could even do interlocking-puzzle-scarf joint! However, most laser cutting systems are only 3 axis, so it's easier/cheaper to only cut your splice at right angles. www.cutyourway.com |
#32
| The next time I find a 6 axis laser cutting machine with a 50" x 98" bed, I'll have to run over and grab it up . . . |
#33
| Try Mazak, but remember they are the most expensive |
#34
| I'm not sure what you're attempting to push Peter, cut files, machines, new customers, but CNC machine cut anything for a back yard builder is just cost prohibitive. Developing a cut file or paying to have one done, paying to have the materials cut, transportation is a given. How can a typical back yard builder, who's project is an 18' or smaller, single chine, powerboat (80% of the market) with maybe a dozen scarfs at most, justify the cost of machine done joints? Their trying to get the whole boat in for less then a couple of grand and your joints cost how much of a percentage of the project? For what? Accuracy that isn't remotely necessary on a set of plans that only go down to an 1/8 inch? They're doing the project to work with their hands. That West System scarfer attachment is junk except on rough work that will be heavily faired latter. |
#35
__________________ LP ---------- God bless the open minded people of the world. LP |
#36
| Whats important to consider is that you can..at this moment....order marine ply by the sheet with the puzzle joint pre cut into the sheet of ply, ready for work. . In many applications the puzzle joint is the correct choice, so why not use it when called for. . |
#37
| Again,Michael you've offered nothing. How about substantiating your claim that; Quote:
#38
| I don't know what kind of luck you fellas were born with but if I ordered puzzle joined ply wood I'm betting the ends would be so banged around and buggered up by the time I got them from the shipper, that I would have to spend a day sanding just to get them to fit together again. |
#39
PAR, normally I wouldn't waste my time responding to your thoughts, But for your benifit, I suggest you really should get out more and open your mind. . I can walk to the local furniture, kitchen cabinet, component maker and ask him to cut puzzle joints with his milling machine in any grade of ply I purchase. I live in a small city. Many milling machines around. In the US I can simply order ply ,pre cut, from http://www.clcboats.com/shop/product...e-plywood.html If you have situation i which the puzzle joint is the best joint for the job, order it pre cut . It with save you the time spent fabricating a template. . |
#40
| Well, looky here the reply. A finger joint for 50 dollars (CLC offering), on a piece of 1/4" Okoume plywood, well yes, that's an economical option. So glad you pointed this out. Lets see a single $50 joint on an $80 sheet of plywood, well you've discovered something here. As usual, you can't justify any of your your comments, though on this one rare occasion you have offered up a link to a service, where a single joint jacks up the base product cost by 40%. |
| joining plywood with puzzle joints??? | Psuedomonas | Wooden Boat Building and Restoration | 0 | 11-03-2010 04:50 PM |
| Joining plywood to cast iron keel in an old Thunderbird | Hercules | Wooden Boat Building and Restoration | 12 | 01-07-2008 08:06 PM |
| Prop puzzle | ejfla | Outboards | 4 | 07-05-2007 05:10 PM |
| Rigging puzzle | messabout | Sailboats | 8 | 05-20-2007 11:38 AM |
| Joints in bright-finished plywood | WoodButcher | Wooden Boat Building and Restoration | 7 | 01-18-2005 08:30 PM |
