Old 03-17-2007, 05:43 AM
michelaos michelaos is offline
Hull: West system and balsa (duracore) sandwich
I have a project to run a construction of one dragon boat of 90 feet
(Asian Boat race canoe) 50 crew
i want to use balsa sandwich with two layer at +45/-45 inside
and the same layers composition outside plus one horizontal for classic boat looking and longitudinal strenght
i prospect to use for wood one local species to be very close in weight, smell and veneer than the red cedar
i have already built one mini transat on this process (whith mahogany)
But i expect any advises, experiences (good or bad)
For all your help
thanks so much
Best regards
Michel Couderc
PS/ sorry for my poor english
Old 03-22-2007, 01:59 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
The question I would have regarding your plan is will the duracore strips bend enough to conform to the curve of the hull at the 45 degree angle? If they will I think it will work fine. I have heard of many boats built in a very similar fashion. It sounds like you will need a lot of duracore and a lot of epoxy.
Balsa strip boat hull. medusaboat Fiberglass and Composite Boat Building 11 03-09-2007 01:02 PM
Balsa cored hull? Itchy Fiberglass and Composite Boat Building 36 11-21-2006 11:49 AM
Sandwich hull panel to plywood bulkhead T joint??? leegrace Fiberglass and Composite Boat Building 4 02-01-2006 08:42 PM
West system old wooden boat. jeff goldberg Wooden Boat Building and Restoration 7 10-01-2005 01:26 PM
west system vs fiberglass resin chippy Fiberglass and Composite Boat Building 4 06-04-2004 09:00 AM
