Old 06-22-2007, 09:02 AM
RandyS RandyS is offline
Rep: 10 Posts: 5
Hull Restoration Wolverine
Hi all,
Last Aug. I posted a thread on a Wolverine Wagemaker. I finally picked it up. Now the fun starts. From what I have been told this is a cedar lapstrake bottom over molded plywood. I am looking at stripping it. From the searches I have seen here I believe that using a heat gun would be the best solution. I want to try to maintain the wood grain above the water line and not effect that coating if at all possible. To see the boat search for Wolverine Wagemaker. I don't know what the cedar might be caulked with, will it be O.K. to use a heat gun for stripping? I would not want to boil out any sealant. I think a heat gun would be fast and localized. I just want to strip the waterline and below. Am I on the right path? Once I open it up I will need some help with any repairs also. Thanks, Randy
Information/Help Wolverine Wagemaker RandyS Wooden Boat Building and Restoration 14 08-17-2006 04:20 AM
1952 Wolverine Wagemaker Restoration in Michigan kpearless Materials 1 07-07-2006 04:25 PM
Help first restoration.wide hull seams. steady45 Wooden Boat Building and Restoration 7 06-25-2006 09:27 AM
Traditional Restoration Comet Wooden Boat Building and Restoration 4 03-17-2006 12:31 PM
Restoration grt05 Wooden Boat Building and Restoration 4 06-12-2004 11:59 PM
