Old 11-16-2006, 02:21 PM
fishweed fishweed is offline
Rep: 10 Posts: 45
how to's "building a wooden sailboat mast"
The lenght of the mast is appox 30 feet, it will go on a motorsailer, first, what type of wood, and are there any sites where I can look at some construction ideas?
Mark
Old 11-16-2006, 03:04 PM
Crag Cay Crag Cay is offline
Rep: 547 Posts: 629
Have a search on here and google for 'bird's mouth' mast construction. There are loads of sites that will tell you all the basics and people on here will be more than happy to fill in the details.
Old 11-16-2006, 04:45 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
The ultimate wood for masts and spars is Sitka Spruce.
Check A.L. Condon. Good stuff is getting harder and harder to acquire.
Like Crag Cay said, Google "wooden masts" & there should be alot of information. If you familerize yourself with the basics & differing construction techniques, you can direct more specific questions to the forum members.
It will also give you better judgement when dealing with the info supplied by forum responses.
A couple of good books on wooded boat contruction would be useful if they have sections on mast constrution.
Take care.
TGoz
Old 11-17-2006, 11:56 PM
Rep: 2891 Posts: 8,792
There are a number of ways to skin a cat or stick as it may be. Sitka spruce is a well loved spar building material, prized for it's light weight and compression strength. Many masts have been constructed from this evergreen. It's particularly well suited to solid masts, but in my opinion, isn't the best material for larger masts or for use on cruisers. Because of it's status as pole building lumber, I've offended a bunch of traditionalists, but that's not such a new thing either. In racing boats, beachable and light weight craft, this wood makes at lot of sense. In heavier, larger, off shore vessels, it isn't my first choice in hollow mast material.
A step by step guide will generally have to be purchased, but a good overview can be had from a number of previous threads on this forum. Use the search tool and some key words will be birdsmouth (as mentioned) spars, masts, etc.
Old 11-18-2006, 09:19 AM
timgoz's Avatar
PAR,
What would be your first choice(s) of wood for hollow mast construction?
TGoz
Old 11-18-2006, 09:43 AM
Eric Sponberg's Avatar
Rep: 2447 Posts: 1,376
If you look at the structural properties of various woods (high strength and stiffness for light weight, known as specific strength and specific stiffness), three woods rise to the top--Port Orford Cedar, Douglas Fir, and Sitka Spruce. Sitka spruce is the generally favored one because of its light weight and plentiful supply. Port Orford Cedar is rare and hard to come by. Douglas Fir is quite acceptable. All these woods accept modern glues like epoxy quite readily.
"Skene's Elements of Yacht Design" by Francis Kinney offers a whole chapter on the engineering of spars, particularly in wood. I am sure if you looked back through Woodenboat magazine you would find all manner of articles on spar design and construction. There may be other books on the subject which you can scan through at www.bluewaterweb.com.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 11-19-2006, 05:42 AM
A generic answer would be Douglas fur for a serious cruiser stick. A racer/cruiser should think about aluminum or other materials. If the yacht forces the use of wood and performance is desired, then Sitka.
Old 11-23-2006, 07:29 PM
BOATMIK's Avatar
BOATMIK BOATMIK is offline
Deeply flawed human being
Rep: 190 Posts: 273
Eric
Great suggestion Eric.
Skene's has both the method and a worked example in the back.
Also the rectangular masts in Skene's can be made much lighter than a birdsmouth mast - purely because the rectangular section has a higher second moment of inertia - is stiffer for the same weight
It is also easier to build - fewer parts.
And fewer parts and lighter weight for the same stiffness mean less material - so it is cheaper.
We have been doing some work on thinner wall section rectangular masts and it seems that with modern glues it may be possible to go down to thinner wall sections than Skene's suggests. But for the motorsailer the standard 20% wall is a good balance of robustness and cost.
Michael Storer
my boat pages
Old 12-23-2006, 08:32 AM
fhrussell's Avatar
fhrussell fhrussell is offline
Boatbuilder
Rep: 30 Posts: 134
Here are some links to basic info.... it may be helpful....?
http://www.everything2.com/index.pl?node_id=1400819
http://users2.ev1.net/~fshagan/mastm.htm
....and one of my favorites....
http://www.starclassics.org/Sliding_...making-of.html
Dumping keel and mast to make boat "unsinkable" SeaSpark Sailboats 43 01-29-2008 06:30 PM
Design thoughts on a 9" wooden Sailboat JohnBloch Wooden Boat Building and Restoration 54 06-30-2006 05:27 PM
Design thoughts on a 9" wooden Sailboat JohnBloch Sailboats 0 06-12-2006 06:59 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
