Old 05-08-2005, 09:55 PM
phillip phillip is offline
Registered
Rep: 10 Posts: 25
honduran mahogony
Hi! I have made belaying pin racks and cleats out of honduran mahogany. I also carved out a coaming for the companion way. Now I'm wondering if I'll be able to steam this wood enough to bend it ? Will this wood take a steamed bend?
Thanks Phil
Old 05-08-2005, 11:11 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Depends how tight the bend is.... if you steam it enough and bend it slowly enough, mahogany can bend fairly well, but only to a point.... perhaps a 2-3 foot radius for every inch of thickness is as tight as I would ever try to go with steaming, but that's just a guess....
Old 05-09-2005, 06:42 AM
Registered
Rep: 10 Posts: 25
Thanks Matt: Probably not a great choice of wood; But it will look good if it'll go.
Phil
Old 05-09-2005, 11:32 PM
Rep: 1397 Posts: 7,216
It bends fair. Mahogany won't make a tight radius like oak. Make sure you soak the wood for two or three days before steaming and it won't split.
Old 05-10-2005, 06:57 AM
Registered
Rep: 10 Posts: 25
Would it help to heat the coaming on the inside of the radius while jigging it?
Thanks Phil (soak/steam/heat/?)
Old 05-10-2005, 08:42 AM
It is better to heat the outside of the curve. That is the part of the wood stretching. I use a propane torch and keep it wet with a brush and water. A helper makes it easier.
Old 05-10-2005, 07:47 PM
Registered
Rep: 10 Posts: 25
Thank you for the response and sharing your knowledge.
Phil
