Old 07-03-2005, 05:11 PM
Jasen Jasen is offline
Rep: 10 Posts: 7
Home built prop shaft seals
I'm getting ready to build my 1st. peddle power wooden boat.
I'm looking for some help/info on building the prop shaft seal.
So far all my ideas aren't looking so good on paper.
Thanx,
Jasen
Old 07-05-2005, 11:15 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Seals are one of those things that are easier to just buy. A commercially made "stuffing box" seal unit, sized for your hull and propshaft, and filled with a specially-designed propshaft packing seal material, will be cheaper and last longer than most homemade alternatives. Or you could swipe the lower unit from a fried outboard; it has all the seals and such already in place. But this is one of the few things that just doesn't work too well homebuilt.
Old 07-06-2005, 04:29 PM
Rep: 10 Posts: 7
Marshmat,
I looked into buying one, but what I've found on the web is a size problem. My prop shaft is only 1/2" The smallest I've found is 3/4".
I might be able to sleave it at the seal point with some 1/8" pipe stock.
Thanx,
Jasen
Old 07-06-2005, 05:29 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Go to a plumbing parts place. Tell them what you want to seal. They can show you dozens of seals that are perfect. Cost will be nothing, and a common standard size.
Old 07-09-2005, 03:02 AM
Rep: 10 Posts: 7
Now why didn't I think of that
That greased up the 'ol wheels.
Found some streach fit rotory shaft ring seals over at McMaster-Carr.
They sound like more then enough to do the job, and for only $3 and change.
Ok, plus shipping
Thanx
dual prop shaft ? yipster Propulsion 31 05-21-2005 03:51 PM
Prop Shaft LADYLOVE Propulsion 0 04-30-2005 01:26 PM
Prop Shaft Machining Asia Help Game-Fish-Asia Propulsion 3 04-25-2005 05:43 AM
prop shaft read out at packing gland davy jones Propulsion 0 09-02-2004 11:41 AM
Prop shaft vibration sailvayu Boat Design 0 02-21-2003 05:11 PM
