Old 05-15-2008, 06:21 PM
Donny2oars Donny2oars is offline
Rep: 10 Posts: 6
Hey all newbie here
Been doing research online and reading for months. Finally got the nerve to get into wooden boats. I found a really good deal on 1950'S home made runnabout. It needs finishing and some rot removal but all and all is in good shape. It was built by a father and son in the fifties. I have been looking around the net trying to find pics of one just like her. I have seen similiar ones but not just quite the same. One immediate question I have is about the back of the boat. It looks like it was meant to be a barrel but was never finished as one. the motor sits on wood about a half foot in from the edge and the rest is open. I have pics but cant figure how to compress them enough to post them here. Anyone know where I can host them and provide a link? Or I could send via email, thanks all Russ
Old 05-15-2008, 07:11 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1943 Posts: 4,195
Hi Donny, welcome here.
Download faststone capture - it's freeware. The screen captured pictures are a nice size for uploading. Save as JPG's.
Regards
Fanie
Water ! Just gimme water !
Old 05-15-2008, 07:39 PM
Rep: 10 Posts: 6
ok thanks here are the pics
here are the pics thanks for the help
Hey all newbie here-boat-1.jpg  Hey all newbie here-boat-2.jpg  Hey all newbie here-boat-3.jpg
Old 05-16-2008, 12:19 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
Looks to be cedar strips on steamed oak. It's very unusual, with a very rounded bottom. I've never seen anything like it. My guess is that it's an experiment. Upside down it would be a barrel back. Interesting.
Old 05-16-2008, 01:57 AM
Meanz Beanz Meanz Beanz is offline
Boom Doom Gloom Boom
Rep: 585 Posts: 2,286
I know Jack about it really but my immediate thought is that the boat would probably benefit from some rails to help handling, turning and promote earlier planing. The stern setup looks OK, looks like an attempt to limit cavitation.
Old 05-16-2008, 08:48 AM
Rep: 10 Posts: 6
Yes it is a cedar strip boat, not sure what type of wood the forward deck is or trim/ seats maybe oak? It is too bad that it is fiberglassed, wish it wasnt. It does have small side rails where the red paint meets the white on the side.
Old 05-16-2008, 08:57 AM
I mean rails just below the waterline to give the hull an edge, similar to the way rails work on a surfboard.
Old 05-16-2008, 09:01 AM
Rep: 10 Posts: 6
Lol duh got cha, yeah it possibly could benefit. Story goes that they used to water ski with it.
Old 05-16-2008, 09:05 AM
Fanie's Avatar
Fanie
Looks like it has a keel in the boat centre though. You will have to be carefull with that when you're on the plane. When you turn and the keel lifts out of the water the boat will slide sideways over the water. When the water surface meets up with the keel again it will suddenly grip. This could make for some eratic turning and can be uncomfortable and even dangerous... someone could be flipped overboard.
I like the length of the boat.
Regards
Fanie
Old 05-16-2008, 09:06 AM
Be interesting to see how she goes, best of luck with it
Old 05-16-2008, 09:10 AM
Rep: 10 Posts: 6
thank you sir, im looking forward to it. I am stripping her down now, debating on if I should strip off the glass, hull seems/feels solid so I dont know.
Old 05-16-2008, 09:23 AM
Rep: 10 Posts: 6
yeah she does have a keel. Wont be using it for fast going, just slow cruisin. The guy I bought it from said that he took it out on lake superior with his kids last year. Dont think I would do that with this low of a profile boat.
Old 05-16-2008, 06:47 PM
If the glass is well attached I would not touch it, it could prove surprisingly difficult to get off. Maybe you could tap it with a small light hammer to determine how solid the layup is. At a guess with the age of the boat and the nature of the construction I would think that the glass skin is required. The glues that an amateur boat builder was likely to use back then could be better off with a skin of glass over the glue lines. Just a guess, be a little wary until you know what its put together with.
I missed the keel, that would be giving you some directional stability through turns. You would probably only consider rails if it was slow to plane or turned badly. Sharp turns will greatly reduce the keels effect, if you can I would put it through some sea trials before messing with it, note how well she planes, how early, do a few sharp turns etc.Also a day in the water might give you a clue as to how water proof all those glue lines are, see if she takes up water anywhere.
Cheers
MBz
Old 05-16-2008, 07:13 PM
Fanie's Avatar
Fanie
Yeah right. First time the missus awaits you with her hands on the hips I can just see that quick plane to the launch
Put her to water and examine from there, just not on that trailer, it looks kinda over the wall from here. Once she's afloat you would quickly find out her true colors ie stability, leaks, and in general behaviour.
Regards
Fanie
Hey! I need your opinion on Etap 37s! nunzioluka Sailboats 13 09-05-2007 07:01 PM
Hey everyone. Question about molds kitcarguy Open Discussion: All Things Boats & Boating 14 08-08-2007 08:04 PM
hey i need some educating so if u can help plzz do i appreciate greatly! Islandboy Powerboats 1 09-10-2006 11:00 PM
hey an interesting site www.kondosyokai.com louis Press Releases 2 02-28-2004 12:46 PM
Hey guys - need your help eightwgt Boat Design 10 04-20-2003 10:25 AM
