| Help with paint! Hello, I'm building a stitch and glue plywood dinghy and I need some help with the paint. I am taping the joints with epoxy and glass. Also I will coat the hull with epoxy, or at least the bottom of it, with what is left after taping. I will use polyurethane paint. 1. Should I use sth. between epoxy and PU? will PU stick well to it? Or should I need some in between? I want a cheap solution. 2. Will PU stick well to ply? (possible uncoated areas) Thanks in advance. |
| I wouldn't paint un-primed plywood.
__________________ Hoyt Lighting is very selective and will not strike crap. Wynand N http://www.genocidewatch.org/southafrica.html http://www.saabc.net/ |
| Would recomend sealing the wood with expoxy, and then almost any paint, including latex house paint, should stick to it. See also: http://www.jemwatercraft.com/forum/v...21&hilit=paint Rich S. |
| ok, sealing it completely will cost me another 15 euros (1lt of resin) but I guess its worth it. then im gonna finish with 2 coats of pu paint. thanks for the help! |
| Paint | waterbaby | Materials | 0 | 08-10-2009 09:42 AM |
| To paint or not to paint over 3m 5200 | BurnabyRocket61 | Materials | 3 | 09-01-2008 09:45 PM |
| My paint has come off ! | Dave-Fethiye | Wooden Boat Building and Restoration | 12 | 08-16-2007 07:15 AM |
| Need Paint Help | flydog | Boat Design | 4 | 04-15-2007 04:39 PM |
| Paint? | anotherhassel | Powerboats | 3 | 12-22-2006 06:00 AM |
