Old 10-28-2009, 08:54 AM
lewisboats's Avatar
Obsessed Member
Rep: 373 Posts: 1,062
Originally Posted by Seanmay1 View Post
thanks for the responses guys and lewis that seems like a good idea. I think im going look for a good price on epoxy and fiberglass and just tape the seems and paint the rest. I know it wont last as long, it doesn't have to last forever if i can get a few years out of it i will be happy. Im sure after i build it if everything goes well it wont be long before im out there building a better one.
ClarkCraft is a bit spendy but the epoxy is a nice 1:1 and you can get small amounts rather than having to buy a gallon or more.
Old 10-28-2009, 09:42 AM
helen07 helen07 is offline
Rep: 60 Posts: 32
i have unqualified design questions to ?
What do those who know think of these dimensions for a displacement hull on a fishing trawler ?
Length 15 metres
Width 7.5 metres
Draft 2.5 metres
I'm assuming this will give for a very slow boat unless a very thirsty engine is used ?
It is common belief among fishermen that lifting poles should always be placed a half length of the boat , i find this difficult to believe as the width of a boat is usually approx one third of it's overall length so why can't poles be placed wherever , if it can lift that weight on it's side rail without capsizing then why would lifting the same weight say on the stern for example cause any problems as it would have 3 times the counter balance . Your thoughts on this please .
An earlier convo on here got me thinking about the so called rule beater fishing boats design and having brought myself up to date with the latest fishing rules i have been designing a hyperthetical fishing boat that is built to adhere to the rules while offering a level of safety and comfort only currently available from catamarans . Catamarans have no fish hold worth mentioning so are not appropriate .
Emptying nets inside the stern rail should in my mind prolong the life expectancy of a trawler considerably as several tons slamming into the midsection of a hull inevitable takes it's toll on any boat regardless of it's build .
I am without qualification and so i will be grateful for any criticism also , though it's very early days , my final drawings might one day end up at a shipyard as i have family still at sea .
Old 10-28-2009, 11:03 AM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 592 Posts: 2,800
Helen,
welcome back!
You would be placed much better here:
Fishing Vesels stability
with your questions!
You are talking serious business, this is a amateur section.
Though there have been some "misinterpretations" in the past, you´ll get more valuable info from the pro´s.
Regards
Richard
Fortior est qui se quam qui fortissima vincit Moenia.
Old 11-05-2009, 06:54 PM
pungolee pungolee is offline
Rep: 10 Posts: 86
Good Gravy! I thought we were beyond all this,I haven't been here in a while.
Buy the best Epoxy there is, use stainless or bronze screws, use the best wood you can afford,the best primer and decent paint.
I work at a place that gets tung oil by the drum.I like to use it but the only way it would work in the application you are suggesting is to build a closely(hint;skilled) jointed hull from air dried wood and then SOAK the thing in hot tung oil.
It still would need the same process a year later, that is if you didn't drown.
Go to Norway and take the Viking Boat Class in Onslo.
New guy in need of help. meangreen Fiberglass and Composite Boat Building 17 07-27-2009 03:37 PM
New Guy. TXBoudy Boat Design 1 07-31-2008 10:01 AM
New Guy, glue questions? BHOFM Materials 7 07-17-2008 05:50 AM
And *another* new guy... RipSlider Boat Design 1 07-16-2008 02:49 PM
New Guy Here with some questions Re: Chev 350 and Exhaust Galaxie_406 Sterndrives 23 04-01-2007 09:19 PM
