| for something like that you don't really need plans. 2 1x12s for the sides plus 1 for the ends, a couple of sheets of ply, some PL Premium, drywall screws and paint. The blue one is 10 ft long, so I just measured up 6" on the side at the front, and measured back 36" and sprung a batten to give the bow curve. Use some scrap ply for a butt block at the joint and use lots of glue. Enjoy it for a few years then chuck it and build a new one if it isn't holding up. Steve |
| Well, I didn't use plans -- I'm just throwing together something that has a flat bottom, tapers slightly towards the front (because that seems a reasonably boat-like idea) and will fit in my garage. But, not being very experienced in boat building, I can see why it might be nice to use plans for a tested and proven design. There's a lot (a heck of a lot) I don't know about boat design. For example, I'm not certain that the glue/screw joints between the hull base and sides won't come apart if I put my foot down heavily in the wrong place when it's in the water. I don't think they will come apart, but I'm not certain. And I'm not sure if the 1/4-inch ply I'm using for the base is really strong enough for the load I envisage (2 adults and 2 children + supplies). I've put additional ribs and skids in place to strengthen the bottom, but whether they're really necessary or not, I just don't know. I don't really know whether the transom (3/4 inch) is strong enough to support an outboard motor, even a small one. This is kind of why I want to try it on the water before I put a lot of effort into finishing it off That way, if it collapses or sinks, I'll only have wasted a few hours and some scrap timber. |
| Kelvin, dont worry about softs spots etc. Thats why you wear a PFD. I was in a plywood 19' that came apart as we were jumping waves in a lake. It didnt sink, the part with the motor attatched tried to sink but the control cable and fuel hose kept it attatched to part of the boat. No problem. Lewis I like your idea. Quick, and Disposable. I may go after that. Mine's gonna be 12' with a 48" bottom. Similar to the 10' in the photo. |
| jon boat question | lloyd | Stability | 8 | 06-06-2007 01:46 PM |
| new jon boat | rick5963 | Boat Design | 10 | 05-02-2007 12:47 PM |
| jon boat | chodedawg | Boat Design | 2 | 06-20-2006 10:22 AM |
| jon boat | rwbrabbits | Boat Design | 0 | 03-19-2006 11:55 AM |
| 15' jon boat | Tim Dykes | Boatbuilding | 7 | 12-06-2004 03:26 PM |
