Old 11-16-2011, 04:07 AM
metin_mehel metin_mehel is offline
mech.eng.
Rep: 10 Posts: 92
hammerton paint
Hi,
I mad an epoxy coated beach type small boat. I painted it with acrylic primer. For the final coat I would paint it with acrylic car paint. But some peoples suggest me hammerton paint would be more resistant to water. What do you think about this? Thank you.
Old 11-16-2011, 07:38 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
You mean Hammertone I think. This coating is what you might see on a micrometer body. I used to use Hammertone paint quite a bit, the type that is available from a can, a one-part paint.
I don't know if it works well in water but I know it's also available as a two-part formulation.
Probably, the two-part will hold up pretty well. The single-part spray can formulation is rather brittle so it's easily damaged.
Either is impossible to blend in when repairing.
Very impractical to keep such a surface up perfectly due to difficulty blending in when those inevitable scratches occur.
Old 11-16-2011, 10:42 AM
Rep: 3125 Posts: 9,403
Most of the hammer finishes I've seen are single part polyurethanes, though I'm sure an LPU is available too. I'd be worried about a compatibility issue with an acrylic primer and a solvent based top coat. Unless the primer was one of the new water based epoxy formulations, like that from System Three, then I'd stick with recommend top coats. Contact the primer manufacture and see what they have to say, but I can tell you they'll recommend their own top coats first (naturally), though an honest tech will offer other brands as well.
Old 11-16-2011, 11:27 AM
mech.eng.
Rep: 10 Posts: 92
Do you mean hammertone paint may not be compatible with ac. primer?
Old 11-16-2011, 02:34 PM
Yes, I'd worry that an acrylic primer might have difficulty with a single or two part polyurethane, of course depending on the resin formulation, vehicle, etc.
To paint or Not to paint that is the ? ezrollin Boatbuilding 15 08-05-2011 03:33 AM
Paint waterbaby Materials 0 08-10-2009 08:42 AM
To paint or not to paint over 3m 5200 BurnabyRocket61 Materials 3 09-01-2008 08:45 PM
My paint has come off ! Dave-Fethiye Wooden Boat Building and Restoration 12 08-16-2007 06:15 AM
Need Paint Help flydog Boat Design 4 04-15-2007 03:39 PM
