Old 10-02-2008, 03:19 PM
elioti elioti is offline
Rep: 10 Posts: 21
Gunnels For Boat, What Wood To Use?
hi there, i need to replace the gunnels on a 34 ft grp motorboat. They are currently oak, but rotten. Whats the best wood to replace them with, oak?, heard iroko can split? There are three layers of 1 inch thick by 5 inches. Also any advice where to get the wood in the u.k? Any advice much appreciated!
Old 10-02-2008, 04:55 PM
Rep: 3125 Posts: 9,403
English oak is much different then the white and live oak used here in the USA. Which is on your boat?
The hardwood you should consider may need the following requirements: rot resistant species, dense heartwood, preferably with an interlocking grain that resists splitting or checking, fastener holding power, a species that receives glue well, clear and straight grained stock, flat sawn will wear better if not chafe strip is used, but quarter sawn will be dimensionally more stable and better looking, a species that machines well, etc.
As to where you might find some of this mystery wood, check with the locals down at the near by marinas and boat shops. They'll know what is commonly used, is available and more importantly will have suggestions about which species work best and why. Bring pastry in the morning (old boatbuilding trick), you'll get much better cooperation.
Old 11-14-2008, 06:39 PM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 343 Posts: 724
What about using Marine Plywood. 3/4" should do.
If your going to paint it or put the Non-skid stuff on it, what would it matter whether the grain showed?
Old 11-14-2008, 07:18 PM
Plywood makes for a lousy rub rail. It doesn't willingly bend to the compound curves found on most boats, it's not especially tough when compared to a nice hardwood rub, it requires a fair amount of additional effort to finish off, the end grain will always be a point of moisture entry and it's not as strong longitudinally as solid lumber of similar species.
Old 11-14-2008, 11:42 PM
thudpucker's Avatar
Rep: 343 Posts: 724
Excuse me, I didn't know he was talking about a rub rail. I was thinking of the Decking on the edge where you walk fore n' afte alongside the cabin.
What would make a good cheap rub rail would be limbs. The lower limbs of some hardwood trees are fairly long, long enough to get six feet or so, and if you split them in half, you get double.
Then comes the wood preservative etc.
Some Crab pot rub rails have Hardwood planks with Split limbs for the skidders.
Wooden Gunnels For Grp Boat? elioti Fiberglass and Composite Boat Building 3 11-16-2008 10:13 AM
Unknown Wood Boat snowtires Boat Design 2 07-06-2007 12:03 AM
Cherry - useful boat wood? byankee Wooden Boat Building and Restoration 29 06-03-2007 11:21 PM
fabricating your own aluminum gunnels? Seaspan Boat Design 15 04-08-2005 11:27 AM
Wood boat Insurance alanagr1 Open Discussion: All Things Boats & Boating 2 05-29-2004 06:16 PM
