  #31
Old 07-06-2010, 10:27 AM
dskira dskira is offline
Rep: 1305 Posts: 1,372
Originally Posted by daiquiri View Post
No need to apologize, Daniel. I am in learning mode here, and you surely have many things to teach.
Do you add something for fasteners, resin, varnish etc. or is it included in the 15% margin?
For fastening I made a total estimation and put the weight to the allready found main center of gravity.
For the paint I use the total square area to know the gallons needed, then put this weight in the same manner as the feastening.
I use paint which dry by oxydation, so the weight remain the same when dry (-5%)
The 15% soaking weight is put at the center of gravity of the planking and keel.
In case I use several gallons of coal tar under the waterline, I made a separate weight for that and put it on the center of gravity of the lower planking.
Daniel
  #32
Old 07-06-2010, 10:42 AM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
thank you Daniel, its good to know how you work these out,
no Daiquiri, i dont know exactly
  #33
Old 07-10-2010, 07:00 PM
Peter, don't leave us in the dark.
When you can we would like more pictures and your work story.
If you don't mind of course.
Daniel
  #34
Old 07-19-2010, 05:22 PM
thank you Daniel i must post some info
  #35
Old 08-07-2010, 06:05 AM
  #36
Old 08-07-2010, 06:06 AM
  #37
Old 08-07-2010, 12:47 PM
That my friend its what I call fast and well built.
Beautiful. From framing to finish, I am impress.
Congratulation Peter, you are the best
Daniel
  #38
Old 08-07-2010, 12:53 PM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,356
that was pretty dam impressive Peter
my hats off to you ship mate
I am skeptical of the deniers diatribe
  #39
Old 08-07-2010, 01:03 PM
thanks guys, but its only about 3/4 finished, the beds are in, but the engine is not in, probably a volvo,
  #40
Old 08-07-2010, 01:25 PM
Boston's Avatar
thus proving the points system is seriously flawed
