| glued lapstrake question I'm building a shellback and can't find a measurement for the overlap - 1 " 3/4" ???? The manual mentions filling in the space with epoxy/fillet material - completely filled or with a small radius? Any help much appreciated. |
| Gray Duck, I see no one has responded yet. If nothing comes up soon just post again. Glued lapstrake is not my forte. Wooden Boat magazine I think has some books available on the subject. They ran a multi issue arcticle once on a ply lapstrake design by Ian Outhred (sp?). This boat was epoxy and glass sheathed. Try the forum search function also. It may prove helpful. Like I said, post again in need be. There are people here that can help. Your post must have slipped past them. Welcome to the forum GD. Tim |
| In small craft, under say 17 - 18' then 3/4" is fine, usually. The general rule is 3 times the planking thickness. A little less on racers, maybe 2.5 times the planking thickness. |
| You might want to join this forum...http://www.woodenboatvb.com/vbulletin/upload/ |
| thanks for the replies |
| Converting a Carval Plank Hull to Glued Lapstrake Ply | Stephen Hopkins | Wooden Boat Building and Restoration | 1 | 01-19-2007 02:59 AM |
| Glued Lapstrake | Jim Herbert | Boatbuilding | 4 | 08-31-2006 04:39 AM |
| Glued Lapstrake | Jim Herbert | Fiberglass and Composite Boat Building | 0 | 08-30-2006 09:17 PM |
| Composite replacement of a edge glued strip planker | Roly | Fiberglass and Composite Boat Building | 18 | 10-15-2005 12:56 AM |
| 1 part boats-no glued flanges? | seamonkey | Fiberglass and Composite Boat Building | 0 | 09-27-2004 12:51 PM |
