Old 05-11-2010, 05:37 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 572
Full size plans
Does any one know of a taditional small sailboat plan other than the Haven 12 1/2. That does not require lofting?
Over the years I have spent nearly all of my money on boats, beer, and women. The rest of it I just wasted.
Old 05-11-2010, 06:01 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Of many hundreds of small sailboat plans out there, the Haven -12 1/2 is an expensive little yacht that can take years to build. Is the 12 1/2 the type of boat you want to build, or something lighter/cheaper/easier?
Old 05-11-2010, 07:11 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 572
Alan
Yes, a Herrishoff / Alden type vintage boat is what I am looking to build. I have lofted in the past, but I cheat and use the computor then plot full size, but it never fails, something is always off and fairing is a nightmare. I just finished restoring a 38' Benny, but health, money and a nagging wife have restricted me to whatever I can build in my garage. "Your not giving that marina one more dime". I like the Haven, but I was looking for a choice.
Old 05-11-2010, 10:28 PM
alan white's Avatar
Kap, I'm not familiar with which boat plans are sold full size, but I can suggest a few boats.
I myself own a boat similar to the 12 1/2, but it's a one of a kind and who knows who designed it.
Look at the Atkins site...http://www.boat-links.com/Atkinco/Sail/Teach.html
See "Teach".
Or something similar to this: http://www.storerboatplans.com/David...idcatboat.html
When I have some time I'll think better and come up with some nice designs. It's late...
Old 05-12-2010, 10:22 AM
uncleralph uncleralph is offline
Rep: 10 Posts: 17
Here is a glued lapstrake variation of the Haven 12-1/2.
http://www.brooksboatsdesigns.com/about.html
I don't know for sure if it requires lofting or not, but it says the plans comes with full size paterns.
Old 05-12-2010, 12:53 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 572
Both boats are nice. But if I'm going to spend 2+ years sweating in my garage it will have to be for something worth the time and money. I once built a Roberts 27' plywood walk around. I did not feel that I was building a real boat the right way. So far the best (traditional) boat I have found is the Haven. I can't convince my wife that a boat like a racing T boat would be fun. She says it's to much work to sail. --guess we all gettin old.
Old 05-12-2010, 05:01 PM
alan white's Avatar
Check this out---- http://www.gartsideboats.com/catsail2.php#spartan
And---- http://www.benford.us/pdf/PuffinLiberty.pdf
Too big?
Old 05-12-2010, 05:42 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 572
Gartside has some nice boats, but both sites say that lofting is required. If they would give out the CAD file I could plot the lines full size, but I know just enough not to attempt lofting the old fashion way. Been there done that-- it wasn't pretty.
Old 05-12-2010, 07:55 PM
alan white's Avatar
Maybe if you can't find the right boat with full size patterns, someone could loft it for you. A small hull wouldn't be too expensive and you could get your own patterns from the loft floor.
Old 05-12-2010, 08:45 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 572
That's not a bad idea. That opens up a lot of choices. Are you aware of any design similar to a Dragon, scaled down from 30' to @ 20'? I always wanted a Dragon....
Old 05-12-2010, 11:10 PM
alan white's Avatar
How about a Dark Harbor 12 1/2? http://sailboatdata.com/viewrecord.asp?class_ID=5773
About 2000# displacement. Also some forum talk by a builder of the boat, maybe you could contact him. http://forum.woodenboat.com/showthread.php?t=94869
Old 05-15-2010, 07:53 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 572
Yes
The Dark Harbor is a great boat. But a really tough build with a difficult fixed keel, and not too much more than offsets to use. I have always liked that design, but I'm a little intimidated by it, also.
Old 05-15-2010, 11:22 PM
alan white's Avatar
You won't get into anything under 20 ft with that look. You might do plywood, hard chine or multi-chine. Easier in every way. Have you heard of Phil Bolger's Chebacco series? There are two versions, glues lapstrake and plywood. The plywood model is, to my eye, the more elegant. In fact, those chines accentuate the curves in a way the lapstrakes cannot do.
1900 lbs, trailerable, probably you could get by without lofting.
http://dory-man.blogspot.com/2009/03/chebacco.html
Old 05-15-2010, 11:28 PM
alan white's Avatar
I think Bolger's Chebacco 20 plan set is available full size. Wonderful boat. The plywood version is the best looking.
Old 05-16-2010, 07:59 AM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 572
But it is still a catboat. The Dark Harbor 20 by S&S is nearly a duplicate of the Finnish Dragon, but a 30' it's too big for a garage buid, but the 12 is ideal. It looks as good on a trailer as it does in the water. So we are down to a choice between a Haven or the 12. Lots of pros and cons with each to consider. I have to do a lot more research on the D.H. 12. That is my first choice, but I'm worried about the plans. I haven't found a web site yet dedicated to a build, but I'll keep looking.
From scale model to full size. tom_fry24 Boatbuilding 1 12-27-2006 01:15 PM
Model to full size jammer Boat Design 6 11-05-2006 02:12 PM
Scale Model vs. Full-size AstroTux Boatbuilding 3 08-08-2006 06:14 PM
Printer for Full Size Plans b_rodwell Boat Design 21 04-02-2005 03:51 AM
full size plotting b_rodwell Boat Design 7 09-21-2003 01:44 PM
