| Frame Jig Question I'm getting ready to attempt my first project (a small mahogany runabout) with plans purchased from Clarkcraft.com. Looking at the frame setup diagram, I see reference to a building jig, but the measurments are not clearly defined. Does anyone have/know of any links to pictures of frame jigs? Thanks |
| There is a photo of a building jig here: http://glen-l.com/methods/plywood/mthdpw01.html Essentially, the two horizontals that the frames mount on must be level lengthwise and athwartship. The height needs to be enough for the frames to clear the ground. Could be higher, but at some point it would be difficult to work on the boat. Width is generally not critical, unless it is an inboard, in which case the spacing must be sufficient to fit the motor mount spacing (usually 22" to 26"). This is all based on the type of jig shown on the page referenced above. There are other ways to make a jig. 24" is a good spacing. Depending on the vee in the bottom of the boat, some frames may have to be notched into the stringers. Typically, a boat with a lot of rocker (sailboat) may have frames blocked above the horizontals, while others rest on or are notched into them. |
| Thank you Riddley. The link is perfect. |
| Frame Mods... | roeslerjd | Sailboats | 0 | 10-30-2006 08:31 AM |
| Attaching Flooring frame to Rib Frame. | jeff goldberg | Boat Design | 0 | 05-24-2006 02:34 PM |
| Scarfing Jig | qadeer | Boatbuilding | 13 | 01-03-2006 07:01 PM |
| Keel And Frame ? | MACINAW | Metal Boat Building | 5 | 05-05-2005 01:20 AM |
| Jig for laminating frames? | Mohan Pakkurti | Wooden Boat Building and Restoration | 8 | 02-10-2005 07:22 PM |
