| Floor in tinny I'm halfway through repainting an old 14ft quintrex runabout and now for the floor which I really need some help.I need to know what kind of wood to use for the frame work to support the floor,And what kind of plywood for the floor and how to fix it to the boat.Any input would be great.Thanks Phil. ![]() ![]() The floor will go between the front seat and the back seat when I put it in . |
| Phil, Hard yakka painting a tinny eh! Use alloy for the trensverse floor members and marine grade plywood for the sole. The ply must be primed, underfoated and painted on BOTH sides, using whatever you decide for a brand system. International is good. You can also use a product called Everdure, it is an epoxy based antifungicidal primer, it soaks into the ply and certainly adds to the longevity. The Everdure is thinned for the first coat, as per the instructions on this web site if you cannot get anyother details. http://www.yachtpaint.com/australia/default.asp before painting the bare hull you have to etchprime alloy...no shortcuts in that game... see also Altex/Devoe paints NZ, they make great commercial surface coatings, very suitable for alloy...think it was 201 from memory.
| What is this under the floor? | wheresbob | Powerboats | 9 | 08-06-2006 10:26 PM |
| New Plywood Floor | grp.boat | Materials | 5 | 11-28-2005 10:57 PM |
| Replaced Floor | leroy | Fiberglass and Composite Boat Building | 5 | 08-05-2004 09:41 AM |
| floor gone- now what? | Guest | Boatbuilding | 0 | 06-23-2003 05:37 PM |
| What to use for floor? | Materials | 4 | 08-06-2002 12:23 PM | |
