Old 09-21-2008, 05:31 PM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 459
Tiki
Hi over the years I have refinished the teak on the boat many times, mostly with oils, look good quick, but don't last too long exposed to the weather (about one season, two if your lucky).
So this year, because of a serious investment on a complete restoration, I thought I would varnish, at least on the helm pieces There under the protection of a hardtop.
Here are samples, about 7 coats of clear high gloss
Fair winds & calm seas
Old 09-22-2008, 06:29 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
[quote=BHOFM;228961
The truth; I used one of my wifes old make up brushes to apply the teak
oil, sable, soft. An old T-shirt to rub it off.[/QUOTE]
One of my wives was cool with letting me use her stuff too. The other one got a little upset. I guess I should have asked her to take off the t shirt before I tried to rub down the oil with it.
Old 09-22-2008, 06:39 PM
BHOFM BHOFM is offline
Rep: 247 Posts: 458
Women are funny, You buy them a house, buy them cloths,
buy them food, tell them you love them. Turn your back for
one minute and they chew through the ropes and run off.
Old 09-23-2008, 01:50 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
I have found that success with oil finishes has a lot to do with how finely the wood has been sanded. I've done a lot of oiling of wood gunstocks, furniture, and cabinetry and when prepping the wood, I've gone as far as 600 grit paper (which gets the wood to reflect light like a mirror), and then and only then oiled to the point of saturation.
What happens is the wood shines a lot more than it would if only sanded to 180 grit.
Unlike clear finishes such as polyurethane or varnish, oil depends entirely upon the shine produced in the wood before it gets coated.
Over time, if the wood is kept oiled, it develops a beautiful patina.
Not for abovedecks necessarily, but great for interior furnishings. Once correctly prepared, the oiling (especially tung oil) protects better than any other coating and should never require wooding.
You do it once, and simply renew the oil on a regular basis.
Alan
Old 09-23-2008, 06:13 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
Thanks Alan,
That is good advice. I have never been successful with oil. That is why everything on my boat is bright. I want to oil the teak seats that are set up like decking and the handrails and cockpit grating. Would you still recommend the same pre application work? Which oil, or just stick with tung? 6-7 coats?
Old 09-23-2008, 07:56 PM
alan white's Avatar
Especially with hardwood, the sheen before oiling is what creates the shine after oiling.
That said, my experience is limited to interior wood, as I described.
Products like Deks Olje (a two stage process, I think) are formulated for dealing with sun, rain, and salt air, but my experience has been with varnish outdoors on boats. This is primarily because I do so much painting relative to brightwork, so I can choose a finish for looks even if it is a bit more work.
Oil is oil, of course, so I'd experiment and compare a surface sanded to a high degree and another only sanded top maybe #180. My guess is you'll be surprised to find that oil can look pretty good when the wood is finely sanded.
Old 09-23-2008, 08:17 PM
Swiftlady's Avatar
Swiftlady Swiftlady is offline
Rep: 10 Posts: 2
Our lovely "Swift" is almost entirely teak and we found varnish very unsatisfactory - it peels easily because teak is so oily.
in our mega restoration job now were stripping right back and going for oils
would support PAR's advice post #7
Old 09-23-2008, 08:20 PM
Rep: 247 Posts: 458
Par beat me severely when I mentioned steel wool, I failed
to say, it was to be used in the shop during construction
and that it was stainless steel wool!
Old 09-24-2008, 12:29 AM
Rep: 2891 Posts: 8,798
Even stainless steel wool will rust, use bronze or one of the polymer variety.
You can get varnish and polyurethane to stay stuck to teak, but it's the prep (isn't it always) that determines you're likelihood of success.
The varnish has to get a grip on the wood, which it can't if the natural oils are still there and you've not insured the varnish can penetrate. I have a "special" blend of particularly nasty chemicals that I use to remove the oils, just before varnishing teak. Then the varnish goes on thinned and hot (to lower viscosity). If you can heat the wood, then permit cooling, even better, just like trying to eliminate out gassing in epoxy work on raw wood.
With a few hot thin coats of varnish, which progressively decrease the solvent percentage, you now have "keyed" into the wood with the varnish and if the wood was clean and oil free, you'll get good durability results.
It's got to go down thin, without temptation to cheat the "build" coats with a few thick layers. The build or bulking coats are the basis for the varnish job. This is what saves your future efforts, so you can't skimp here. Once sufficient film thickness is bulked up, the handful of finish coats top off the job. These are the sacrificial coats and you'll remove these over and over, during the life of the bright work.
  #25
Old 09-24-2008, 03:53 AM
Crag Cay Crag Cay is offline
Rep: 547 Posts: 629
I do completely the opposite (in the de-oiling stakes but agree with the thin layers) and have had a lot of success with keeping varnish on teak in place, even in the tropics. I don't fight the oil, I go with it. I start with Deks Olje #1 and then several coats of #2 before starting with a traditional oil based 'yacht varnish'. (Whatever name International uses in the various parts of the world).
However there are lots of other factors that determine whether varnishing will be a success. I've seen people blame 'the oily wood' when in fact it's just a **** varnish job. Their work wouldn't have stayed in place on a wool blanket.
  #26
Old 09-24-2008, 04:19 AM
Previous Member
Rep: 0 Posts: 0
what works in the UV down here will work anywhere, I use the Ole, ,
finishing lalusiva Services & Employment 1 07-20-2007 10:25 AM
finishing material vishnubaiju Fiberglass and Composite Boat Building 3 03-23-2007 03:23 AM
teak minus teak plus seattle lite Materials 1 04-02-2005 03:36 PM
metal finishing paul roberts Materials 0 08-30-2004 10:06 PM
Bottom Finishing Corpus Skipper Wooden Boat Building and Restoration 0 08-25-2004 10:02 PM
