Old 06-04-2008, 09:10 PM
tarrat68 tarrat68 is offline
fiberglassing plywood hulls
I'm trying to decide if I should fiberglass a glen-l classic runabout plywood hull with fiberglass. I know the strength adds value but I've heard that it can cause the hull to rot faster. Is there any truth to this rumor? what would you do? Is it alright to epoxy and paint only? Isn't this the more traditional approach?
tarrat68
Old 06-04-2008, 09:22 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
it will only rot if you dont glass it right. do "shody" work,,and ya it will rot. and i've never done it,,(the epoxy dudes will ring in soonz),but i think i read another epoxy thread and they said it can be done,,but just epoxy and paint is better then just paint,,and just paint is better then no paint or anything.
hehe ,,,,,Jim------>
Old 06-05-2008, 12:19 AM
Rep: 2891 Posts: 8,798
This is a well debated subject and you serve yourself well if you did a few searches on the subject.
As a rule, epoxy on wood (painted or varnished of course) doesn't add any significant strength. It does seal the wood, but only if total encapsulation techniques are employed.
Epoxy bonding fabric to wood doesn't impart substantial strength either, unless you use a pretty fair thickness of fabrics. In other words, a single sheathing of moderate weight fabric over wood, will provide little more then abrasion resistance (and the most common reason for doing so), very little noticeable strength, unless you use some of the high tech fabrics (bring you first born to the supply house).
If you haven't epoxy encapsulated your planking, I would strongly urge you to not 'glass the exterior. Just paint her and keep after the maintenance when the needs arise.
If you feel you must add cloth to the outside of your boat, but haven't encapsulated the planking, then use one of the fancy fabrics, such as Dynel or better yet Xynole. They absorb much more epoxy, but will dramatically improve the abrasion resistance compared to regular cloth. Dynel is about 3 times better and Xynole is about 6 times better then similar weights of S cloth (the regular stuff).
If you have embalmed the planking with at least two (much better if three) coats of unthickened epoxy , then you have a good prospect for fabric sheathing. This will increase you abrasion resistance and water proofness a substantial amount.
Fiberglassing/sealing a 12ft aluminum boat with plywood rracechase Fiberglass and Composite Boat Building 1 05-18-2008 08:20 PM
Fiberglassing Plywood for Impact and Stiffness Ed3 Fiberglass and Composite Boat Building 3 03-04-2008 05:05 PM
Fiberglassing Plywood for Impact and Stiffness Ed3 Wooden Boat Building and Restoration 3 03-04-2008 09:41 AM
Fiberglassing plywood deck KMD Fiberglass and Composite Boat Building 5 02-26-2006 12:49 PM
fiberglassing plywood boat deck KMD Materials 11 11-10-2005 12:49 AM
