| Hi Par, Thanks again for the help. I will epoxy all the parts seperatly before perminatly joining them. |
| Sorry, don't mean to hijact this great thread but does Dynel wet out clear with epoxy? I hear it has much better abraision resistance than lightweight glass fabrics.
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| No, Dynel doesn't wetout clear, but it does provide about 3 times the abrasion resistance compared to regular 'glass. Xynole provides about 6 times the abrasion resistance and it too doesn't wet out transparent. Ray, you don't have to pre-coat everything, just the contact areas within joints and other areas that will be out of reach after assembly of a frame, floor, etc. I usually assemble with wet joints, using screws as temporary fasteners. I either leave the screws in or remove them, then coat each frame assembly as a unit afterward. This method permits the green on green technique on the bulk of the pieces being coated. I can gear up for an epoxy run from hell, rather then bunches of small batches as I get pieces ready for goo. It always seems like I have epoxy in the pot and I have to start looking around for things to smear it on, so I plan full day epoxy runs, where I'll be mixing and applying goo, fabric and fillers until I get pissed off enough to stop torturing myself. Tape off the joints, so you get goo where you need it, but no place else, for a neat job of it and less sanding when finishing the encapsulation process. |
| looking for satin clear | jigerbetter | Fiberglass and Composite Boat Building | 2 | 07-23-2007 06:37 AM |
| Optimum Area & Overlap? | RHough | Sailboats | 5 | 11-16-2005 02:26 PM |
| What clear is the best ? | Sagabu | Powerboats | 0 | 07-29-2005 01:15 AM |
| Clear Gelcoat | Dawgfish71 | Materials | 8 | 04-05-2005 01:33 AM |
| overlap geni's or aggressive non-overlap jibs? | blue messiah | Boat Design | 1 | 10-22-2004 08:52 AM |
