  #46
Old 03-28-2010, 05:16 PM
apex1
Originally Posted by teoman View Post
Ok I think I get the point. Thanks...
Richard there is one epoxy on the Turkish market called "Teknomarin" ERA 4000. Did you heard about that one ??
any idea, would you recommend it ??
Forget you heard about it...............
basically it is not a bad formulation, but unstable. (I mean it does not provide the same properties in each supply)
R
R
  #47
Old 03-29-2010, 03:20 AM
teoman teoman is offline
Rep: 10 Posts: 24
ok thanks, I never Heard of it ...
hehe
  #48
Old 03-29-2010, 08:58 AM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
The original poster must *definitely* do as Ilan Voyager says a couple posts back. If you have used epoxy as a fastener anywhere, but leave the wood open to the elements, the wood will breathe (ie: expand and contract with varying moisture and temperature). As the wood changes shape and size, it will break free of the epoxy, if left untreated.
You can sheath the outside with glass/epoxy for durability, but you MUST put 3 coats of epoxy on the inside of the hull, absolutely encapsulating all wood so that you can be sure it doesn't breathe and go to work loosening the existing epoxy joints you show in the photos.
  #49
Old 03-31-2010, 02:40 PM
Rep: 10 Posts: 24
Would you guys rercommend I mix anything such as West Microfiber to the resin when applying the inner side of the boat ??
  #50
Old 03-31-2010, 04:51 PM
I wouldn't suggest you mix anything with the epoxy. Just roller it on, 3 layers of it. You aren't applying it for strength in there, just to keep the moisture level of the wood stable. That's its only purpose.
  #51
Old 04-02-2010, 04:46 PM
wolnym wolnym is offline
Rep: 10 Posts: 3
Abrasion ??? From whom ?? When you expoy both sides the wood bewteen epoxy start faster rot. In stripe planking method stripes inside the both you must paint using breathable varnish, 5-6 layers.
  #52
Old 04-02-2010, 05:30 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
What comment are you referring to about abrasion, wolnym, and haven't you heard that epoxy inside and out is exactly how normal modern strip-builds are done? Varnish is a very high maintainance coating compared to epoxy.
You may be more familiar with the older type of edge-fastened strip construction.
  #53
Old 04-02-2010, 05:47 PM
Rep: 10 Posts: 3
Alan,
modern and wooden for me it's not the same. Maybe I'm not perfect in English but epoxy for me means using cold molded method on polished wood. Put the epoxy resin with mat glass on both sides of the boat it's not a good idea.
p.s.
If I something missunderstood, I'm sorry.
  #54
Old 04-02-2010, 07:29 PM
alan white's Avatar
No problem. I think you may misunderstand, but not speaking English well, it's still good to see you posting. I am not sure what you read that you don't agree with. Which post?
  #55
Old 04-03-2010, 02:00 PM
apex1
Well it is in fact a very good idea when the design was done accordingly.
Regards
Richard
Fiber cloth with epoxy on wooden hulls urisvan Wooden Boat Building and Restoration 7 03-09-2010 11:23 AM
Fiber orientation on hull? bntii Fiberglass and Composite Boat Building 2 09-30-2006 11:47 AM
Fiber orientation on hull? bntii Boat Design 8 09-25-2006 05:47 PM
Fiber Glass Sheathing of a wooden boat. BCB Wooden Boat Building and Restoration 5 06-13-2006 11:46 PM
Finest woven carbon fiber cloth? Splint Fiberglass and Composite Boat Building 1 06-20-2005 02:41 PM
